99 Passport CEL nightmare!
Google
Web AF
90centurypiece
10-25-2007, 12:10 AM
So, first I had P0172(rich bank 1), P0174(lean bank 2), P0300(misfire), and P0401(EGR insufficient flow).
Then I replaced the IMGs. After reconnecting the battery and driving a few miles the CEL came back on and I had: P0401(EGR) and P0172(rich bank 1).
Then I cleaned the EGR. CEL came back on and I "erased" the codes with my tool.
CEL came back on and now I have P0172(rich bank 1), P0174(lean bank 2), P0300(misfire), P1133 show as "pending" on my tool ( H02S Insufficient Switching Bank 1 Sensor 1), P0401(EGR), and P0174(lean bank 2) repeated.
I am about to give up on this thing. Does anyone have a good idea of where to start? I'm leaning towards the see how many holes $100 in ammo makes thing. I can't believe my buddy bought this with the CEL on.
Thanks again for all the help here!
Gizmo42
10-25-2007, 11:01 AM
Did you use the updated 13 ft lbs torque on the intake bolts when you replaced the IMG? Also did you use an inch lb wrench instead of a ft. lb wrench? ft lb wrench wont be nearly accurate enough at that low of a setting.
Anytime I've seen those codes together its always been IMG cracked.
2000izusu
10-25-2007, 11:55 AM
i agree i would double and triple check the img!
amigo-2k
10-25-2007, 12:01 PM
did you clean the egr tube?
90centurypiece
10-25-2007, 03:34 PM
I did tighten to 13ftlb, but I do not have an inlb wrench. I would hate to think I ruined $60 in gaskets. Well, I guess I will eat the cost of that I try re-replacing them. Do you think the upper gasket is okay or should I replace both again? Thanks!
90centurypiece
10-25-2007, 03:36 PM
I followed the instructions in the FAQ. One whole can of intake cleaner down the small hole. Pintle moved fine on the valve itself. Any way to check the pintle with a meter? Thanks!!!!!!
99 Fronty
10-25-2007, 09:37 PM
Speaking of IMG bolt torque. Do you think it wise to back off the bolts to the new torque after the gaskets have been in service for a while, or is it too late?
Andrew.
90centurypiece
10-26-2007, 11:33 PM
UPDATE: While he was driving, the CEL went off. I figured it burned out so I pulled codes again. Without doing anything to it, it dropped the H2OS code and now has: P0172, P0174, P0300, P0172 (pending), and P0300 (pending). How can it throw a hard code AND have the same code pending? Are we still thinking another IMG job is a good start? I picked uo another set of gaskets and an in/lb torque wrench today. Thanks!!!!! :banghead:
I should also mention I "erased" the codes to see what happens next.
Google
Web AF
