TIRES 30 x 9.5 15
S10SNODOG
10-24-2007, 08:40 AM
I have a 2003 S-10 crew cab LS I think I can put 30 X 9.5 15 ( that's the bigest tire i can put in that wheel well) on that truck is OK to put mud terrain BF Goodrich or is that to aggressive I have a good deal in the works $ 40 a tire for them with 90 % tread life left thank you so much in advance Anthony.....will it do harm to the truck
S10SNODOG
10-31-2007, 09:46 AM
ended up putting opn BF Goodrich ALL TERAIN T/A KO 30 X 9.5 15 I LIKE EM drive good not so much humm......
sickcallawayc12
11-17-2007, 08:31 PM
That is pretty close to the max tire size allowed without a lift or suspension work I think. Many Blazer owners use BF Goodrich. Good tires. Pretty expensive a lot of times though.
ZL1power69
11-17-2007, 09:19 PM
a mud terrain in that size may not fit. the tread on the mud terrain is a bit taller than the all terrain. a bfg all terain 30x9.5x15 is basically the biggest tire you can put on a blazer with stock suspension and no lift.
ninjafied
12-02-2007, 10:25 AM
the only thing is if you'll be driving on the street alot remember to rotate your tires. i have mud t/a's on mine front tires are cuped baddly
