2006 ram clutch pedal
View Full Version : 2006 ram clutch pedal 2006 ram clutch pedal jeddi20 10-24-2007, 09:19 AM HEMIDAZE 10-24-2007, 12:23 PM If it is leaking inside it is most likely the clutch master cylinder, not the slave. jeddi20 10-24-2007, 03:20 PM If it is leaking inside it is most likely the clutch master cylinder, not the slave. my apologies. they replaced the clutch master cylinder 3 times. and its still leaking on my floor. HEMIDAZE 10-24-2007, 07:13 PM The only things that come to mind .... They have a bad batch of parts that they don't know about. I ran into this on a rear window latch on a Chev extended cab. Possibly something is out of alignment that is causing the failure. Not so easy to find and not too likely. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
