service 4wd light on99church 10-24-2007, 02:34 AM have a 99 blazer with np236 transfer case (4 button on dash,auto4wd,2hi,4hi,4lo).when i turn key on all the lights on the selector switch light up and go off, when i start truck, auto flashes, after i drive it a while it will settle on auto or 2hi. I am unable to press any of the selector buttons and shift to 4hi or 4lo or 2hi or auto.had the codes read and they were B2725 and C0367. i have pulled the atc fuse from the fuse box under the hood. i did this because sometimes, it felt as though it was in 4wd, but lights did not indicate that. i have replaced the 4 button selector switch, vac switch on firewall, front shift cable. still same problem when i plug fuse back in. constant service 4wd light. i can hear clicking underneath (encoder motor)and the tccm from inside, any help or words of wisdom greatly appreciated , thanks MT-2500 10-24-2007, 09:45 AM Was the codes cleared and did they come back? The B code is for selector switch voltage or wiring circuit problem. The C code 0367 is for front axel control circuit problem. I would suggest you check the front axel circuit real close. You will need a good factory repair manual info or a all data info on the repair flow chart for the codes. You will need a real good volt/ohm meter. Check all voltage readings as outlined in the repair flow charts for codes that were cleared and come back. http://www.alldata.com/products/diy/index.html Good luck MT vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
