93 S-10 Blazer - rear won't open
Google
Web AF
dmb359
10-23-2007, 02:09 PM
I just purchased an old 93 S-10 Blazer, and the rear won't open. The lock cylinder is missing AND the glass won't pop open with the release button in front.
Is there a way to get to the inside of the rear gate without it being open, and is there a common fix for this. I don't see any screws or anything for removal of the interior panel on the rear gate in order to remove from the inside.
or is there any other things I should look for for getting the glass to pop open. I don't care so much about the tailgate opening, but I would like to be able to pop the glass.
blazinman08
12-14-2007, 10:31 AM
ight so you have a push button opened right what you have to do is have someone push in on the rear glass and you press the button this should unlock the glass and for the back latch no lock cylinder if you can see in there you should be able to see a circle thing with a notch in it take a screwdriver and try and turn that circle and wiggle the back hatch if this does nto work message me i will tell you in more detail
dmb359
12-14-2007, 12:43 PM
the push button does nothing, it doesn't pop the glass currently. I just hear silence and nothing happens when pushing the button.
The inside of the "missing lock cylinder" location has been pretty beat up from the last owner trying to use a screw driver, I don't know if that will work too well anymore.
blazinman08
12-14-2007, 01:28 PM
so your push putton is not working umm let me think for a minute and ill give you a solution
blazinman08
12-14-2007, 01:31 PM
have you checked all your fuses
dmb359
12-14-2007, 01:34 PM
lol...yes, fuses are fine
the wiring appears fine connected to the back of the button. I think it has to do with the connection in the tailgate. I don't know how to even get inside there without being able to open the back, it seems like the screws or whatever are holding the panel on, are hidden along the sides when it is closed.
blazinman08
12-14-2007, 01:39 PM
if your inside your vehicle looking at the back window can you see the latch or no
dmb359
12-14-2007, 02:06 PM
no, it's a flat panel all the way across from side to side, no visible screws, latches, seams, or anything
blazinman08
12-14-2007, 03:12 PM
k so try this i just did it on mine if you look inside the lock cylinder you sould see a circle thing with a notch take a flathead screwdirver and stick it in the and try and move it in a circular motion this should unlock the window try it and then come back
Google
Web AF
