4 Wheel Disk
Google
Web AF
LordofSheeps
10-22-2007, 11:51 PM
What parts do you need to add rear disks?
blindeyed
10-23-2007, 02:02 AM
Backing plates to hold the calipers on the rear axels, the calipers w/ mounting brackets, the 2 e-brake cables, brake lines going to the rear, and 2 brake hoses to connect to the calipers. You'll probably also need pads and rotors also after all that.
GreyGoose006
11-07-2007, 12:27 AM
and unless there is a decent proportioning valve already in there, which there wont be, you will need a proportioning valve from a car with rear discs.
blindeyed
11-07-2007, 12:54 AM
and unless there is a decent proportioning valve already in there, which there wont be, you will need a proportioning valve from a car with rear discs. Not necessarily.. the V6's with 2-wheel disc and rear drums had the same proportioning valve as the other Y87 packaged V6's and V8's that came with 4-wheel disc's. I know several people who have swapped the rear drums to discs and left the proportioning valve alone and have had no problems at all with the proportioning of the 2.
Google
Web AF
