Front End Problems
Google
Web AF
gtmay
10-20-2007, 01:38 PM
I have a 1997 Pontiac Grand Prix GTP with 127000 miles on it. When I turn the wheel to the left at slow speeds, it feels like the tire is wobbling. It also makes a thumping noise at slow speeds like a belt is broke in the tire. I cannot for the life of me figure out what this is. Any information would be appreciated. Thanks a lot, you guys provide some great info, keep it up.
Tony
maxwedge
10-20-2007, 01:49 PM
Possible it is the tire switch it around see and what happens, look for play in the hub and bearing or a broken cv boot indicating a bad outer cv joint, gotta start somewhere, basic checks.
BNaylor
10-20-2007, 01:53 PM
I agree best thing to do is a tire rotation before thinking it is other steering and/or suspension components. Also, with over 100K miles the tie rod ends mainly outer are a common problem. A bad tire with a bad belt or lump which should be obvious if you do a close inspection of the tire will cause the thumping sound or a worn out tie rod end to clunk.
bjnickol
11-15-2007, 11:05 AM
hey gtmay, I have a similar problem with a 97 Grand Prix.
Did you ever find out what was causing your problem with the wheel ("When I turn the wheel to the left at slow speeds, it feels like the tire is wobbling.") If so please let me know what you found out! Thanks!!
Google
Web AF
