need some amp help
Rickottman
10-18-2007, 06:27 PM
ok i have two 12" subs with 460 watt amp and 400 watt regular speakers with 80 rms i want to run two amps at the same time but how do i hook up the RCA wires my deck only has one set of outputs is there an adapter or can i splice these
THANKS GUYS!
THANKS GUYS!
4g63gst20
10-18-2007, 07:47 PM
i'm not all crazy about audio anymore but on this set up i'd get a crossover for lows and highs, there might be different kinds but i had a kicker crossover back in the day, it had ONE input and 2outpus (4 rca), 1 for subs and 1 for regular speakrers
darsh39
10-19-2007, 09:30 AM
I think you have big craze of audio ..Wll i suggest you should relpace your emp. your problem will be solved..
Rickottman
10-25-2007, 07:29 AM
o ok i found this amp that has line/in rca and line/out rca would the line out go to another amp?
PaulD
10-25-2007, 05:36 PM
probably, I would have to read the manual
4g63gst20
10-25-2007, 07:31 PM
some amps have a pass-thru or however you spell it, maybe that's what you are talking about.
PaulD
10-26-2007, 05:46 PM
some will pass thru the full freq range, some pass thru high low or mid, and still others are for strapping 2 amps together .......
