Key Fob Distance
Google
Web AF
Burtnette
10-14-2007, 05:43 PM
1997 Grand Prix GTP 3800
Ok so on the key fob thing when I try to lock/unlock my car or anything on it I have to be like literally 5 feet away from my car for it to work. Is this how it is for everyone else? It seems like it should work from farther away but it doesn't. Also the guy I got it from got a new one but didn't program it so I used the old one for a while (had to be just as close) then once I programmed the new one I still had to be very close. Any ideas?
ericn1300
10-14-2007, 09:26 PM
try changing the battery yet?
BNaylor
10-14-2007, 09:42 PM
GM specifies a range of at least 3 feet and up to 30 feet away. Mine works at the max limit but I have a good battery and the remote is in good shape. Replaced about 6 months ago.
Burtnette
10-14-2007, 10:16 PM
Do you mean the battery on the fob or is there one in the car? Cuz I got the key fob brand new about 2 months ago and ever since I programmed it it's only worked from a few feet away :confused:
proscroby
10-14-2007, 10:47 PM
I had the same problem and changing the battery solved it.
Burtnette
10-14-2007, 11:03 PM
Which battery? Car battery? One in the key fob? A whole different battery? :screwy:
richtazz
10-15-2007, 11:10 AM
Change the battery in the fob itself. Most short range issues are caused by a low battery in the fob. After changing the battery, you'll have to resyncronize it by pressing and holding both the lock and unlock buttons for 7-10 seconds (until you hear the locks cycle).
tblake
10-16-2007, 12:10 AM
I didnt have to do this with mine when i changed the battery
Google
Web AF
