I need some help really badjmtztech 10-12-2007, 01:49 PM ok i have a 98 vtec two door accord. i am having some prob with the engine. i start the car and it runs good. only in park. once i change gears the car starts to shake like its about to run out of gas. some one told me it was my fuel pump, that was going bad. so i just replaced the fuel pump with a new strainer. the car is still doing the same thing again. it still shakes like its about to die. can anyone help me with this prob.... thanks guys. webbch 10-12-2007, 01:57 PM Sounds transmission related to me, but I'm no expert. You say it sounds like its running out of fuel? It's not just a strong vibration (i.e. the engine nearly dies)? If it's a strong vibration that shakes the whole vehicle when you shift out of park, the accounts I've heard from others with similar symptoms frequently turn out to be a cracked or loose flexplate, but I've never experienced it myself. I suppose it could be a problem in the crank or cam position sensor and/or associated wiring, but would expect that to be a little more intermittent. Is there any rattling or grinding sounds accompanied by the vibration that you notice? jeffcoslacker 10-12-2007, 04:43 PM Wow I wouldn't have jumped right to a fuel pump, they usually either work right or they don't work. First thing is does it shake with a rythym, like a dead cylinder, or just a random shake that has no pattern? Does it run OK once off idle? Or runs bad when moving too? Check engine light on? Until I have some better picture of the problem, I can't tell you anything. jmtztech 10-18-2007, 03:11 PM Wow I wouldn't have jumped right to a fuel pump, they usually either work right or they don't work. First thing is does it shake with a rythym, like a dead cylinder, or just a random shake that has no pattern? Does it run OK once off idle? Or runs bad when moving too? Check engine light on? Until I have some better picture of the problem, I can't tell you anything. No its more like a random shake. the car could be running fine. it just every once in a while it dies on me.. it feels like it is running out of gas or something. yeah it also runs bad once i am driving. if i try to accelrate fast it starts to shake and the die. funny thing is, that my check engine light does not come on. i really dont know what else it could be. let me know if you can help. thanks and have a great day vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
