95 altima rough idleSense2k 10-11-2007, 03:22 PM hi my 95 rough idles until it warms up. I recently had the muffler replaced (most of the pipes including the converter) I thought the noise would go away but has not. it just turned 100K and had a tune up last summer. it runs fine except for a hissing noise that pops up at times which i have no idea what may cause it what can i suspect? JudoJohn 10-11-2007, 08:08 PM you probably have an exhaust leak somewhere. that is the cause of a lot of those kind of noises (pops). JoeShmoe 10-15-2007, 05:38 PM Is the check engine light on? It might be a bad O2 sensor. AltimaSteven 11-21-2007, 04:44 PM hey wat up, i wanted 2 ask u something..is it possible 2 put a bigger engine on a altima?..getting tried of the little 2.4 inafogg 11-21-2007, 04:50 PM hissing noise?? makes me think vacuum leak.check all hose connections.sometimes a little 2+2/carb cleaner helps with locating a vacuum leak JoeShmoe 11-26-2007, 11:27 AM hey wat up, i wanted 2 ask u something..is it possible 2 put a bigger engine on a altima?..getting tried of the little 2.4 I don't think the engine bay/mounts can support anyhting else. You could jsut go smaller with some boost. Highly doubt it though. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
