**HELP** Fan Clutch Removal
HanibalTheCannibal
10-06-2007, 06:00 PM
:banghead: :banghead: I cannot for the life of me get my fan clutch nut off:banghead: :banghead:
I know it is reverse from the rotation of the fan's direction. I am trying to loosen clockwise, as I stand in front of engine compartment.
I called my mechanic In texas and he says they use a air hammer attachment (pneumatic?) but in other times they use a large chisel and a good hammering to back the nut off. I tried all that (except I DO NOT have an air hammer).
I have tried to beat the nut's edge with a good cold chisel and hard hits with the hammer. I am getting some good "bites" with the chisel but it still wont back off. I have soaked with some WD40. I am using a large crescent wrench to tuen and I just turn the motor over OR the serpentine belt slips.
How the he11 can I get this off? It is stuck on full blast usually (80% of the time even when cold) and is eating my mileage up.
1994 Jeep Grand Cherokee Ltd. 5.2
**PLEASE** help. Is there a tool to hold the pulley?
PS There are no pulley bolts to hold onto.
xj31
10-06-2007, 10:13 PM
if you are turning it clockwise,you are making matters worse,since that would be tightening it.the tool for holding it is kind of a spanner wrench with 2 pins that go in the holes in the pulley.I usually just tap it with an air hammer and they come right off.
HanibalTheCannibal
10-06-2007, 11:28 PM
Are you freakin serious??? The fan turns counterclockwise, so clockwise should back the nut off, right?
Jeez I really hope that you are wrong, please explain if I am turning it backwards. When I stand in front of the engine bay, the fan turns counterclockwise, so I have been trying to go clockwise (left handed threads, or backwards threads as I call them).
Am I right? Or should I turn the nut in the direction of the fans rotation? That seems that when the fan turns on, the rotatio would loosen it.
HanibalTheCannibal
10-06-2007, 11:31 PM
:runaround: OMG, it just made sense to me:runaround:
So the fans turns counterclockwise, then I should back the nut off counter-clockwise to loosen, because as the engine turns, the fan tightens itself!!!!!
Am I right??
HanibalTheCannibal
10-07-2007, 12:08 AM
:screwy: And to think I consider myself to be somewhat intelligent :screwy:
Well it came off, just like that!! I bet I had that thing torqued to 200 ft/lbs from a day of trying with sledge hammer, torch, crescent, etc.
Thanks a bunch.
**cough cough** theres nothing to see here. Carry on. :popcorn:
xj31
10-07-2007, 01:13 PM
Am I right??
Yeah,I guess the pulley kind of screws itself into the fan clutch as the engine runs.Glad you got it.
