1997 Accord Cracked Radiator
swb1
10-05-2007, 08:07 PM
Hi,
My mechanic tells me that my radiator is cracked and needs replacement. This is going to cost $350. Yikes!! Does this sound like a fair price?? I just had my 150k mile service done 3 months ago. Shouldn't this have been caught then??
Thanks,
swb1
Thanks,
swb1
jeffcoslacker
10-06-2007, 09:08 AM
I haven't priced a radiator for that gen Accord before but it might be correct....what was the breakdown of labor/parts?
An option to consider would be to take it to a radiator shop...if it just has a cracked tank they can replace the tanks, clean the core out and reassemble and paint, reconditioning the entire unit. Generally costs less than half of what a new radiator costs, and their labor rate is usually a bit cheaper than the typical shop.
*** I just looked up a new radiator for it....found units for as little as $94 and as high as $350 for an all-aluminum performance radiator...but the SPI (the brand I used in the shop, good OEM quality replacement) is $329...
So be sure of what they are putting in there. If they are using a crapola $94 Autozone special and taking $250 for labor, it's a screw job. It'll do the job, but might not last long. I'd actually expect to pay a little more for a quality replacement.
But I'd look into reconditioning first...
jeffcoslacker
10-06-2007, 09:12 AM
OH, and to answer your other question....
Not neccessarily. spontaneous things like that can happen without warning, the plastic tanks on those radiators shrink a bit and get brittle with age, cracking is not uncommon. It's been a hot summer (at least here...) running in the extreme heat with A/C loads might have punched it's ticket this summer...
swb1
10-06-2007, 11:26 AM
They just gave me a general quote nothing written, but on there wall they have posted that their labor cost is $80 per hr and he said it was a 2-2.5 hr job. There was no quote as to what the part costs. I guess I have to give them a call.
swb1
swb1
somick
10-06-2007, 11:38 AM
I have bought a radiator from www.rockauto.com. It was the cheapest. After installation I had lots of problems with the radiator cap: none fit in this radiator. So if you buy it yourself I suggest you to buy it with the cap. If you want to pay somebody to do it for you, like jeff said make sure they will put a quality radiator for that amount of money. Labor should not run more than a hundred dollars.
Good luck,
Sam
Good luck,
Sam
swb1
10-08-2007, 02:49 PM
I called the mechanic shop and they said that the radiator is $169 and it is good quality. How will I know whether it is a good quality radiator or just a cheap one marked up? Therefore, I am paying about $175 for labor.
Thanks,
swb1
Thanks,
swb1
wiseguy01
10-08-2007, 04:35 PM
how about this u supply the parts and they supply the labor that way u know ur not getting ripped
drew51074
10-10-2007, 08:25 PM
just do it yourself!!!! its pretty easy, but maybe thats just the mechanic in me speakin.
swb1
01-05-2008, 01:06 PM
The mechanic gave me a break down of the costs:
1. $148 for the radiator (all aluminum)
2. $16 for 50/50 coolant
3. $5 for 4 hose clamps
4. $150 for 2 hrs Labor
Totaling $320
Does this sound reasonable??
Totaling $320
jeffcoslacker
01-05-2008, 05:20 PM
That sounds reasonable. Good price for an all aluminum unit...
swb1
01-05-2008, 08:57 PM
Actually it doesn't look like an all aluminum radiator. Seems like the frame around is plastic (black) and the grill is aluminum. Still seem reasonable??
swb1
swb1
jeffcoslacker
01-06-2008, 12:15 AM
swb1
I wondered, that was awful good. Plastic tanks are the OE design. Like I said earlier, you can buy that radiator for probably about $100 at the parts store, 50% markup is not unreasonable as shops go...some go 100% or more...
They are probably just charging retail list price, that's on the level.
swb1
swb1
01-06-2008, 06:52 PM
Thanks!
