Disabling Torque converterjeffk388 10-03-2007, 07:46 PM My GA 94 V6 slips when adding speed after slow down. I know the bad TCC solenoid is bad. I am planning to disable the TC solenoid until I replace it. Except for increased fuel comsuption, what will be bad sides of it. xeroinfinity 10-04-2007, 08:36 AM If its "slipping" then you have other issues besides the TCC solenoid. Here is a link for the tcc repair procedures. http://autorepair.about.com/cs/doityourself/l/aa011703b.htm Also here is a link for testing the electronics on your trans. http://www.atraonline.com/manuals/general/tetdv/tetdv-c3g.htm jeffk388 10-04-2007, 10:26 AM Thanks for the info. I am pretty happy with disabled solenoids. When the electrical connector was unplugged, the car was very hard to accelerate from stop, but it was fine with shift gear at 2nd speed. If the car is young, I will rush to replace any bad solenoid(s), but I will stick with this trick since it's pretty old. To avoid overheating, a partially open thermstat was installed to lower coolant and tranny fluid temp. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
