2000 Blazer No Lower Rear Brake or Turn Signal Lights
bhesson
09-25-2007, 06:20 PM
Hi, it just happened suddenly today.
I have no lower rear brake lights and no turn signals. The rear running lights work as does the upper brake light at the top of the vehicle. When I use the turn signals, nothing at all on the dash and nothing at all on any of the turn signals.
I checked the fuses in the door and fuses under the hood and all are fine. I checked the rear bulbs and all are fine. I checked the Flasher switch behind the glove compartment and replaced it prior to knowing I also had no lower rear brake lights and it didn't help.
Any suggestions?
MT-2500
09-26-2007, 10:22 AM
Have you checked bulbs?
Check at rear tail lights for 12 volts to it on brake light or turn signals.
bhesson
09-26-2007, 02:48 PM
Thanks for your reply, all the bulbs are good but I figured out the problem after searching here today.
The hazard switch in the turn signal multifunction unit is fried. I wedged a match pack into the switch and all of the lights are working now.
I also called the dealer hoping tp get it covered under the recall but I had already had the unit replaced in 2003 as part of the recall so they won't fix it again for free.
I ordered a new Delco unit for $120 and will get it installed next week.
BTW, how difficult is it to replace the switch?
bhesson
09-28-2007, 07:54 PM
Anyone know how difficult it is to replace the multifunction turn signal switch unit on a 2000 Blazer with tilt?
I have the replacement part and I see two mounting screw holes and one wiring harness connection. It doesn't look too difficult but I'd like to know if anyone has done one and anything I need to watch out for while installing it.
Thanks ...
MT-2500
09-29-2007, 12:17 PM
It is a piece of cake.
Just do not blow air bag.
Always disconnect battery when working on wires.
Good luck
MT
