programming a keyless entry key fob
Google
Web AF
ken531953
09-24-2007, 10:38 PM
Anyone out there know how to program a remote entry key fob for a 2006 Chevy HHR. Lost mine and got one on eBay but don't know how to program it. Any info greatly appreciated.
Old Lar
09-25-2007, 08:25 PM
From an HHR specific forum, the answer I received was back to the dealer for the reprogramming.:2cents:
Onblsht
09-30-2007, 01:43 AM
Yup, Dealer only remotes.
rodeo02
10-05-2007, 10:35 PM
Key FOB programming is definately not a dealer only job, as much as they'd like you to think it is!:disappoin Try this procedure. It's a pretty standard procedure across the GM line: (write-up compliments of nat3ten from trailblazer forum)
"1 SIT IN VEHICLE AND CLOSE DOOR
2 HOLD FINGER DOWN ON UNLOCK POWER DOOR LOCK SWITCH ON DRIVERS DOOR.
3 put key in ignition, TURN IGNITION ON / OFF , ON / OFF.LEAVE KEY IN IGNITION.(DO NOT START VEHICLE, ON POSITION IS THE POSITION BEFORE START)
4 RELEASE FINGER FROM POWER DOOR LOCK.POWER DOOR LOCKS WILL CYCLE.(JUMP UP AND DOWN)
5 PRESS AND HOLD BOTH THE LOCK AND UNLOCK BUTTONS ON NEW REMOTE UNTILL YOU HEAR POWER DOOR LOCKS CYCLE.(JUMP UP AND DOWN) YOU MAY HAVE TO HOLD BOTH BUTTONS DOWN FOR 5- 20 SECONDS.
6 TAKE 2ND NEW , OR OLD REMOTE AND HOLD BOTH UNLOCK AND LOCK BUTTONS DOWN UNTILL LOCKS CYCLE.(MAY TAKE 5- 20 SECONDS)
7 TURN KEY ON, THEN OFF.
YOU ARE DONE, EXIT VEHICLE AND TRY YOUR REMOTE."
Joel
Onblsht
10-10-2007, 02:55 AM
That procedure will not work. It is for earlier style remotes. (98-02 Blazer and other GM models) The HHR uses a completely different receiver and remote type which must be programmed with a scantool.
rodeo02
10-13-2007, 02:22 AM
Man that bites. I know that procedure worked on my 2005 trailblazer (GM T360 chassis). I've done 3-4 GMs that way.
daharris
07-16-2008, 07:51 PM
Regarding this procedure, I bought an extra key fob for my 2008 Trailblazer at my local Chevy dealership. I was told by two people at the dealership that the only way to program it to the car was for them to hook it up to their equipment at the cost of $45.00. I tried this procedure and it worked perfectly the first time through. Thanks for saving me $45.00.
2003Silverado
01-28-2009, 12:36 PM
It may not work for the HHR, but is sure did for my 2003 Chevy Silverado. Thank you Rodeo02!!:evillol:
My battery died for my remote/FOB and after replacing the battery the FOB did not open the doors. I read the manual and found out that the FOB had to be re-synced to the truck. I searched the web and found your thread and man I'm glad I did. The dealer said that replacing the FOB was $61 plus tax.
Thanks Rodeo02 for saving me the $$ and time and frustration with programming the Key FOB.
Google
Web AF
