gas gauge works some timesgrizzly700 09-24-2007, 07:56 PM what is wrong with my fuel gauge in my truck it works some times and sometimes it dont vortecman 09-24-2007, 08:09 PM sometimes my gas guage shows a fuel level and sometimes it don't, but it is never accurate and shows empty when full......tried unplugging the neg bat cable to reset the CPU, but it didnt work... rjeffery 09-24-2007, 11:22 PM Fuel sender is probably bad. Sender & fuel pump is one assembly and located in the tank. You will most likely need to replace it. silverado122775 09-25-2007, 11:35 AM It could also be the cluster.. how many miles on your truck? vortecman 09-25-2007, 09:06 PM had the problem since i had the truck with 90k. 111,000 on 'er now. silverado122775 09-26-2007, 11:32 AM I would have the cluster checked before you start replacing the fuel pump to find out that is not the problem. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
