Weird high idle
Google
Web AF
r6dennis
09-24-2007, 10:33 AM
so I have a 95 beretta that is in decent condition. It has about 184,000K on it and havent had any problems until now. I changed the spark plugs and wires and now it idles really high, i have problems accelerating and i smell gas. The intake manifold is not broken but needs to be replaced soon...not sure if that makes a difference. Also, as im accelerating i can hear a clunk noise coming from the drivers side. I have a hard time getting it to go 65mph and when i push it, it starts to shake excessively. :shakehead any suggestions?
richtazz
09-25-2007, 04:35 PM
check for any disconnected vacuum hose(s) that you may have accidentally knocked loose when changing the plugs and wires.
J-Ri
09-26-2007, 05:00 PM
I would find the source of the gas smell first. That stuff can catch on fire fairly easily, which is bad when it's outside the engine.
anomaly_va_1976
10-02-2007, 03:14 AM
The gas smell may be from the evap canister (under the coolant reservoir)
loosenut74
10-04-2007, 06:46 PM
did you cross wire it when you put the new plugs in?...
Google
Web AF
