90 Civic PGM-FI: Best Place to Check Fuel Sys Pressure?ewidder 09-22-2007, 08:47 PM Where is best location to check fuel system pressure on 90 Civic PGM-FI (SOHC)? Any suggestions most appreciated. wiseguy01 09-22-2007, 10:01 PM on the fuel rail there is a fuel pressure relief bolt and hook up there ewidder 09-23-2007, 12:40 PM Wiseguy01, Thanks for the response. This system is dual-point throttle body injected, so "fuel rail" may not be relavant here. I only see banjo fittings at all engine compartment connections. I could make up a custom pressure tap at one of the banjo fittings, but this would be a project that maybe could be avoided, if one knows where Honda intended the fuel system pressure to be measured and using what fittings. I obviously don't. Thx - Ed Ones&zeros 09-23-2007, 11:19 PM you could check and measure fuel pressure on top of the fuel filter using b&m fuel pressure guage. ewidder 09-29-2007, 03:24 PM Wiseguy01 & Ones&zeros, Thanks for replies. I found the key tap point at the outlet connection from the filter (banjo bolt has tap hole). I was hidden under some hoses & I missed it. Thanks - Ed Automotive Network, Inc., Copyright ©2013
