2000 Grand Am shuts off driving down the road
Google
Web AF
2000GrandAmOwner
09-22-2007, 08:24 PM
Daughter has 2000 Grand AM that has been shutting itself off while driving down the road. Prior to this the Service Vehicle Soon light had been on, but was off when it died. Unable to restart car. Waited approximately 20 minutes and then tried it again. Towed the car home and couldn't find anything electrically wrong with it. Started back up. Drove about 5 miles with cruise on and saw the tach drop off to zero. Tried to restart it and it turns over, but the engine won't fire. Towed back home again...by the time got it pulled back up on the dolly with a come along, it started. What do I do now?
:banghead:
xeroinfinity
09-23-2007, 11:21 AM
What engine and how many miles are on the car?
Anything been replaced recently ??
I'd say when it is running go get it scanned with a scan tool.
This will most likly reveal clues to what might be going wrong.
and Welcome to AF.
2000GrandAmOwner
09-23-2007, 02:33 PM
and Welcome to AF.
It has approximately 134,000 miles, V6. Haven't had to do much of anything to it. Replaced an A/C line and water pump about 2 months ago.
Crystalion
09-23-2007, 05:01 PM
Had similar problem --wire harness going to fuel pump--its short about 3-4ft--push on it and pump came on--no problems since but others !!! GAs love to hate em
xeroinfinity
09-23-2007, 05:08 PM
Yeah could be fuel filter too.
Get the fuel pressure checked, should be between 41-47PSI.
2000GrandAmOwner
09-23-2007, 05:42 PM
Just went out again after replacing the 7X CPS. And guess what happened? Able to drive approximately 5 miles then it shuts down. Takes approximately 9-10 minutes for it to restart....usually. Do not hear the fuel pump start up when key is in on position after it dies. So where is the wire harness to the fuel pump....on the driver's side?
xeroinfinity
09-23-2007, 10:41 PM
Damage is usually close to the tank .... from removing the tank. Just trace the wires back from the tank.
Good Hunting!
Crystalion
09-24-2007, 04:25 AM
The harness for the pump is right at the tank and travels forward about 4 feet till it meets the harness from the engine. Not saying this is your problem but when we had the car up when we moved the harness at the pump (tank) the pump went on. Thats what made me change it. Iv'e had other start complaints due yo fuelpump or injector shutoff but that was because of PASSLOCK. Good Luck keep in touch. You need a group therapy with these GAs.
Google
Web AF
