Engine PossesedLHFmanage 09-20-2007, 04:42 PM I am having a problem with my 93 1500 Chevy. The issue is that the truck will start then after running for a while it will just shut off. Then Have trouble starting. I have replaced the fuel tank, filters, fuel injection unit, fuel lines, fuel pump among various other things. I am in the process of fixing it up. Have any clue as to what the issue is? 777stickman 09-20-2007, 08:54 PM Not sure if the '93's had a "theft deterent (sp)" system in them. May be something to check into. Since you've replaced the whole fuel system maybe you need to look for a spark problem? FAS=Fuel-Air-Spark LHFmanage 09-21-2007, 09:35 AM I have changed the spark plugs and the oil. The truck sat for a two years before I bought it. Payed 100 bucks figured it would be a good fixer-uper love the truck. There is a plug that comes off of the fuel injection system that I think runs to a fuel sensor? could that be the problem? any ideas are welcome vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
