94 GA V6 Auto transmission slip
Google
Web AF
jeffk388
09-20-2007, 11:59 AM
After the trans fluid (Castrol high mileage) and filter were replaced, the transmission slips especailly when the gas pedal was depressed after slow down. I checked the oil level a coule of times and it checked out fine. When I replaced the oil/fluid, a bottle of Lucas Transmission Fix was added for just in case. It seems that the transmission does not like new oil. With old fluid, there was no slip. If I kept the old oil, I will try to put it back but it was trashed ( i mean properly). Does anyone have any idea about how to?
xeroinfinity
09-20-2007, 12:27 PM
Did you check the trany fluid level when it was hot ?
If it was and its slippin, it's probly time for the trany shop!!
Could be many things though.....
jeffk388
09-20-2007, 02:26 PM
The level was checked after I following the procedure on the manual, and so it was warm/hot. It seems that the new fluid is too thin to convert torque. Is there any quick fix like adding more thick fluid? If the TM needs service I would buy a new car since it may be more than the car value.
xeroinfinity
09-21-2007, 10:07 AM
If you put in trans fluid then its the viscosity that it's supposed to be.... thiers not anything you can do for that.
Could be something simple such as a shift solenoid but it could also be something more drastic. The only way to "know" is to have it properly diagnosed by a trans Tech.
Good Luck
jeffk388
09-23-2007, 02:06 AM
It seems that the Torque Converter Control Solenoid is the culprit. I am collecting info and direction for replacing TCC solenoid. To do this, it seems that I need a engine jig and a crane. If there is anybody ever replaced TCC solenoid, please give me some detailed directions.
One option I am thinking is to remove thermostat to decrease T-mission fliud temperature, eventually to increase viscosity. Has anybody tried this trick?
xeroinfinity
09-23-2007, 11:03 AM
Yeah, I've replaced 1-200 of these before it sucks!
Heres a link for the procedures...
http://autorepair.about.com/cs/doityourself/l/aa011703b.htm
Good Luck
Google
Web AF
