set timing on 91 lumina
Google
Web AF
heelhead
09-17-2007, 05:13 PM
is there anywhere i could find out how to set the timing on my lumina, just replaced timing chain and not sure where the settings should be,91 lumina 3.1
maxwedge
09-17-2007, 07:37 PM
There is no adjustment all electronic.
heelhead
09-18-2007, 01:15 PM
so all i do is put chain back on the 2 cogs and it is good
jeffcoslacker
09-18-2007, 03:02 PM
You are talking about cam timing...everybody assumed you meant ignition timing, since you said you already put the chain on....gotta say what you mean, you'll get better answers.
You have to line up the marks on the sprockets with the holes in the guide...here, this should help...
2.5L, 2.8L and 3.1L Engines
http://www.autozone.com/images/cds/jpg/small/0900823d800ecc9b.jpg (http://javascript<b></b>:pop()
Fig. 5: Timing chain and sprocket removal-1996 3.1L engine shown
http://www.autozone.com/images/cds/gif/large/0900823d800ecc9b.gif
http://www.autozone.com/images/cds/jpg/small/0900823d800ecc9c.jpg (http://javascript<b></b>:pop()
Fig. 6: You must use a suitable puller to remove the crankshaft sprocket
Disconnect the negative battery cable.
Remove the timing chain front cover assembly, as outlined earlier in this section.
Rotate the crankshaft until the timing marks on the crankshaft sprocket and camshaft sprocket locator hole are aligned to the marks on the engine block or timing chain dampener. This is the No. 1 piston at TDC (No. 4 firing position).
Unfasten the camshaft sprocket retaining bolt/screw, then remove the camshaft sprocket and the timing chain.If the camshaft sprocket does not come OFF easily, a light blow on the lower edge of the sprocket with a rubber mallet should loosen the sprocket.
Remove the crankshaft sprocket using tool J 23444-A or equivalent puller.
If necessary, remove the timing chain dampener retaining bolts, then remove the dampener.To install:
Install the crankshaft sprocket using tool J 38612 until it the sprocket is fully seated on the flange of the crankshaft nose. Apply a coat of Molykote®or equivalent, to the sprocket thrust surface.
Hold the camshaft sprocket with the chain hanging down, and align the marks on the camshaft and crankshaft sprockets.
If removed, install the timing chain damper to the engine block.
Align the dowel in the camshaft with the dowel hole in the camshaft sprocket. Install the camshaft sprocket and chain, use the camshaft sprocket bolts to draw the sprocket on to the camshaft. Tighten the sprocket bolts to 18 ft. lbs. (25 Nm).
Lubricate the timing chain with engine oil.
Install the front cover assembly, as outlined earlier in this section.
Connect the negative battery cable.
heelhead
09-18-2007, 04:52 PM
thx and sorry i wasnt clear, i really appreciate your help
Google
Web AF
