98 Lum ina
Google
Web AF
civilreeper
09-15-2007, 09:59 PM
3.1 with auto. I have replaced plugs, wires, coil packs, ign module, both crank sensors, cam sensor,cat converter, etc. The car about once a week, has problem holding idle then will not go over 10 mph. Then after sitting a day, runs like nothing ever happened. I have check voltage, very good under load, checked all connectors for corrosion, found nothing. All filters changed and Im running out of ideas. ANyone else have a problem like this ?
luminasrus
09-16-2007, 07:16 AM
Fuel filter, maybe. Have you had it scaned for codes?
maxwedge
09-16-2007, 06:42 PM
Welcome to AF. Check fuel pressure when this happens, 37psi.
Google
Web AF
