2001 Sentra. MIL/DTC falsely condemn O2S. Why?Jim_S 09-12-2007, 03:57 AM I am working on: 2001 Nissan Sentra 1.8 L The "Service Engine Soon" light comes on repeatedly soon after being reset. The DTC is: P0154 Oxygen sensor circuit no response detected (Bank 2 sensor 1) The oxygen sensor is, in fact, capable of switching. It does this rarely, because the fuel control system remains in open loop on bank 2. A new oxygen sensor did not fix the problem. The new sensor switched between low and high as the old one, and about as infrequently. The weird thing is that the scanner says that the output from the oxygen sensor is a constant 1.275 volts. Or on some occassions it stays at a constant 2.65 volts. The oxygen sensor is not capable of producing so high a voltage. And the Vantage trace shows the real output to be in normal range. What could be the cause of such a problem? Is 1.275 volts a substituted value? If so, under what conditions does the PCM do substitution? A couple of other tests. (1) I can disconect the O2S wires and test the voltages on the PCM side of the connector. None of the wires are shorted to 1.275 volts, as seen at the connector. (2) I can unplug the harness going into the PCM. I find continuity in the signal wire from the O2S connector to the PCM connector. But there is one more weird thing here. The pin number at the PCM is one-off from the pin number specified by SomeData :-). So what could cause a good O2S to give a faulty reading at the PCM, as seen from the scanner? Jim S. slideways... 09-28-2007, 09:19 PM a short, or the pcm itself. theres nothing else in the circuit. make sure your DLC connector is operating properly also... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
