ticking noise coming from engine...also never ending service lightWilly Wonka 09-09-2007, 11:19 PM Got an 02 trailblazer EXT, i sometimes hear a ticking noise coming from the engine, is it my fan clutch? do i need a new one? i also have the never ending serive engine light on, it never goes away. i just recently replaced the gas tank, but the light is still there :O ' thx for any thoughts maxwedge 09-10-2007, 04:01 PM What is the code? Info missing is important. Willy Wonka 09-11-2007, 12:04 AM what do you mean? tell me the info i need to give and i will go get it. thanks for any help maxwedge. maxwedge 09-11-2007, 05:17 PM The code that needs to be read with a scanner for the check engine light. fortcarp 09-27-2007, 08:48 PM Have the code read at autozone and post here what it is so the members can better help you with your problem. BRD 09-28-2007, 12:14 PM Your dealer did the gas tank R&R per the EXT/XUV recall, right? I'd get it back to the dealer on that SES - my guess (that's all) would be the fuel system's still sucking a little air somewhere. Dealer should pull codes & trouble-shoot it. Ticking sound is a commonly-reported symptom of a failing fan clutch. You can try pulling codes on that, but the way people usually determine the thing has gone bad is it won't release after the engine has run a few seconds and sounds like a jet engine under the hood, drags performance way down in shifts from first to second gear. Willy Wonka 10-04-2007, 11:27 AM Your dealer did the gas tank R&R per the EXT/XUV recall, right? I'd get it back to the dealer on that SES - my guess (that's all) would be the fuel system's still sucking a little air somewhere. Dealer should pull codes & trouble-shoot it. Ticking sound is a commonly-reported symptom of a failing fan clutch. You can try pulling codes on that, but the way people usually determine the thing has gone bad is it won't release after the engine has run a few seconds and sounds like a jet engine under the hood, drags performance way down in shifts from first to second gear. damn thanks a ton BRD, and i have been noticing it shifting prty hard in the first 2 gears, esp when i start it up in the morning. should i buy my own fan clutch over the inet, and have it installed? they tried to charge me 750 for it being done. i think i can get one for 250 and have it installed for 100? BRD 10-04-2007, 02:59 PM $250 is in the ballpark for that part. However, before you spend any $$$ for a fan clutch replacement, do a couple of things to verify and get the right result. I assume your mechanic or shop has a code reading device. Use it, see what you get back. You may or may not get a code back on that F/C at the time you check it with the scanner. Another way is to get an experienced mechanic who's familiar with TB's and Envoys to drive the thing (after it's up to operating temp) and listen while you ride and listen. Chances are good he'll pick up on it. The F/C was a very common problem. Go down the threads on this page and look at my reply to justin1272 of some few days ago. In the 6/14/07 post I refer to there, you'll find the GM part # and the GM document # (TSB) for the modified F/C and re-flash instructions GM came with approximately at the time they were building model year '05. Be careful shopping on the internet because some of the fan clutches you'll see for sale as "OEM" are the ones that GM ended up replacing because so many proved defective. You don't want that. If enough members/users here need the info maybe Maxwedge could be coaxed into posting it as a sticky. With the part # you can check GM Parts Direct or OEMhq for an online quote. Others may have it in stock as well. Be advised, too, your mechanic or shop needs the eqpt and GM software to do the re-flash once the new F/C is on. If he can do the job right for $100 labor, that's cheap, but don't ruin your radiator removing the old F/C. GM actually advises removal of the grille and pulling the radiator or at least moving it off to the side with the top hose disconnected. That's what runs up the labor time at a dealer's shop. However, some folks have acquired or made pulling tools/wrenches/clamps they say they can do it with while the radiator & grille remain in place. So I'll leave it with you and your mechanic/shop on that issue. Good luck. Willy Wonka 10-04-2007, 03:51 PM I got an updated fc for 140$!! im going to print out your post BRD and take it to where ever i go, ill be taking it to the chevy place i think so... they will probably know. i didnt make sure myself that i needed a new fc but i have been told by 2 different mechanics that i do.. so.. w/e im going to take my car to midus and have them search for an evap leak, i think thats what the service engine soon light is on for.. thanks alot again :) maxwedge 10-04-2007, 03:58 PM Midas for a possibly complex check engine lite? Updated aftermarket F/C's seem to work ok, have one in my 2002, with no reflash, they all are going bad it seems, the OE's that is. If the CEL started after the recall as mentioned, this may have been caused by the dealer, especially if it is a po440-455 code. BRD 10-04-2007, 06:36 PM Congrats on the F/C. I hope it's what the doc ordered. Maxwedge is right that if you can just get one that wasn't manufactured to fail - whether GM's modified one or an aftermkt OE copy - you'll probably be OK. It's the modified GM F/C that requires the re-flash as spelled out in that TSB. Midas might be OK for the SES check. Before you go dumping any $$$ down rabbit trails, however, have you tried a new gasoline filler cap? Maybe an auto parts store would let you. A loose or leaking (air) gasoline cap is the MOST common cause of the SES light not going out once the engine is running. Beyond that, I dunno what electronically-reported code to tell you to look for. Some people have reported "410" and thereabouts and the culprit turned out to be the gasoline filler cao. dube5878 10-04-2007, 07:46 PM I had my car checked out for the same ticking noise. It wasn't all the time and I would notice it more when I would have the air conditioner running. I could sometimes still hear it going 30 mph. Anyway what they told me was that it was the sylenoid telling the fan to speed up, but in actuallity it was going fast enough. So to fix that I would have to go to the dealership and get my computer reprogrammed. Haven't had it done yet because I don't wanna get the sticker shock when they tell me how much $ and how long they will need it for. Willy Wonka 10-05-2007, 12:18 AM Im a fucking newb man, i was alrdy told that the gas cap was bad so i ended up dropping 80 dollars on a new one I dont think it did anything.. envoyxuv 10-06-2007, 10:34 PM I got an updated fc for 140$!! im going to print out your post BRD and take it to where ever i go, ill be taking it to the chevy place i think so... they will probably know. i didnt make sure myself that i needed a new fc but i have been told by 2 different mechanics that i do.. so.. w/e im going to take my car to midus and have them search for an evap leak, i think thats what the service engine soon light is on for.. thanks alot again :) Not trying to stick it to anyone here, but maybe you should just take your vehicle to ONE service department and actually have the codes pulled and diagnosed. Don't assume what the problem is and tell a repair station to fix it. A good tech won't listen to what a customer thinks the problem is- he starts from scratch and diagnoses the problem. Don't get me wrong here- a good tech will also listen to the customer describe the problem so he can accurately diagnose the conern. Describing the problem and diagnosing the problem are two completely different things. By taking your vehicle to multiple repair stations for different problems is asking for more problems. Now, instead of one dealer that knows the history of your car and knows how to take care of it, you've got 2 or 3 shops involved in trying to fix your vehicle, with no idea of its service history. Your check engine light could mean ANY of these codes are set: DTC P0013 PCM P0014 PCM P0105 PCM P0107 PCM P0108 PCM P0112 PCM P0113 PCM P0116 PCM P0117 PCM P0118 PCM P0122 PCM P0123 PCM P0125 PCM P0128 PCM P0130 PCM P0131 PCM P0132 PCM P0133 PCM P0134 PCM P0135 PCM P0137 PCM P0138 PCM P0140 PCM P0141 PCM P0171 PCM P0172 PCM P0201 PCM P0202 PCM P0203 PCM P0204 PCM P0205 PCM P0206 PCM P0218 PCM P0300 PCM P0301 PCM P0302 PCM P0303 PCM P0304 PCM P0305 PCM P0306 PCM P0326 PCM P0327 PCM P0332 PCM P0335 PCM P0336 PCM P0340 PCM P0341 PCM P0420 PCM P0440 PCM P0442 PCM P0446 PCM P0452 PCM P0453 PCM P0461 PCM P0462 PCM P0463 PCM P0495 PCM P0502 PCM P0503 PCM P0506 PCM P0507 PCM P0530 PCM P0562 PCM P0563 PCM P0567 PCM P0568 PCM P0601 PCM P0602 PCM P0604 PCM P0606 PCM P0607 PCM P0621 PCM P0622 PCM P0705 PCM P0711 PCM P0712 PCM P0713 PCM P0719 PCM P0724 PCM P0740 PCM P0741 PCM P0742 PCM P0748 PCM P0751 PCM P0752 PCM P0753 PCM P0756 PCM P0757 PCM P0758 PCM P0785 PCM P1120 PCM P1133 PCM P1137 PCM P1138 PCM P1171 PCM P1220 PCM P1221 PCM P1271 PCM P1275 PCM P1280 PCM P1336 PCM P1345 PCM P1380 PCM P1381 PCM P1441 PCM P1481 PCM P1482 PCM P1484 PCM P1512 PCM P1514 PCM P1515 PCM P1516 PCM P1523 PCM P1571 PCM P1574 PCM P1621 PCM P1630 PCM P1631 PCM P1632 PCM P1635 PCM P1639 PCM P1680 PCM P1681 PCM P1683 PCM P1810 PCM P1860 PCM P1870 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
