'92 Chevy Lumina: replacing lighter fuse
Google
Web AF
6079
09-09-2007, 05:33 PM
'92 Chevy Lumina.
I want to repair my non working cigarette lighter. I have located a fuse panel within the glove box. There are several removed fuse slots with the following names: TL1, TL2, ABS, FPMP.
The following are names that do have fuses, but I thought I would mention in case they are related to the ligher: ECM, 3355B, CLUST, STSY, HZD, PANEL.
Could any of those be the lighter? Would it hurt to try putting in a new fuse with the correct amperage to test it?
Any other suggestions to get my lighter working?
Thanks for reading.
maxwedge
09-09-2007, 06:17 PM
Welcome to AF. Turn the key on check for 12v on either side of fuses, the the dead one, 25 amp, usually is the culprit.
6079
09-12-2007, 11:14 PM
I don't have a volt meter, but none of the fuses appear to be bad. And the only empty slots are named: TL1, TL2, ABS, FPMP, which did not seem able to hold a fuse firmly.
Could there be another fuse panel other than the one in the glove box that contains the fuse for the lighter?
I'm new to this so I am unfamiliar with how to repair it.
maxwedge
09-13-2007, 03:57 PM
There is an under hood panel but I believe the fuse is in the g'box, a test lite cost 5 dollars.
Google
Web AF
