Tire size for 02
Google
Web AF
2string
09-09-2007, 03:45 PM
Can someone tell me if 285x75X16 will fit an 03 1500 without rubbing in the turns?
knogoodidleft
09-09-2007, 07:48 PM
It better not, not sure if you mean 02 or 03, for the 03 i know it wont, cause I tried my friends 305/50/20 on my truck and it barley rubbed a 295/50/20 prob woulnt rub
2string
09-09-2007, 09:46 PM
I'm sorry I did mean 03.So your saying they will not rub? The 50 series are lower profile I think so they probably wouldn't rub anyway.
knogoodidleft
09-10-2007, 01:33 AM
yeah low pro but also 20's and damn those things were chubby, 285/75/16 wont rub, stock rims are pretty similar i wanna say 265/75/17, but it could be wider.
2string
09-10-2007, 09:14 PM
Thank You
kklagge
09-20-2007, 07:41 AM
I have 285's on my 01 4x4 and they don't rub at all
silverado122775
09-20-2007, 11:19 AM
is that with the stock lift?
kklagge
09-21-2007, 05:51 AM
Yes it is stock
Flying_Lavey
09-26-2007, 07:57 PM
The first number is the tire width. So yeah your friends rubbed since it was a 305. A 305 is about 12" wide. a 285 is about 10" wide. 295 is about as wide as you can go without any issues. I had 285/75-16 Nitto's on my old Yukon with stock suspension and there was MORE than enough room.
bigbadram51
09-27-2007, 05:51 AM
All depends on wheels. stock wheels, should fit, maybe minor rubbing. Great thing about stock wheels, you can fit damn near 35" tire with just a TB crank. If your running aftermarket wheels you might rub anywhere from a little to a s*itload... I was running 8 inches of lift with 20x10's (4.5 inches of backspacing and -24mm of off set) and rubbed like hell. Same tires on a 20x9"wheel (almost 5" of bs and -5mm offset) cleared by a mile
judgeman6970
12-01-2007, 10:37 PM
2003 1500 4x4.....305/70(33") tires do fit!!....just level out the truck somewhat, and maybe trim the lower bumper(plastic)....285's fit like they came from the factory, no problem!!
01silverado03z400
12-02-2007, 04:23 PM
Ya 285/75/16 will fit. I've seen people stuff 315/75/16 in with a crank or ford keys and a bit of plastic trimming. Horrible CV angles tho.
Google
Web AF
