Intermittent overdrive due to?
Google
Web AF
orangejbird
09-07-2007, 11:03 AM
Need to go on a long trip soon and want to fix this.
Lately my 2000 w/5.3 Seldom shifts into overdrive.
New filter and synthetic lube with a bottle of Lucas last Feb. Check engine light intermittently on and off.
My scanner indicates miss in #4.
Local wiz kid thought weak solenoid in tranny but used his scanner and found he could force it into OD with the scanner. 3&4 cylinders indicate frequent misses.
Fuel press. reg. new. Injectors check out, new plugs wires. Coils good.
He thought he could hear a noise that may indicate intake manifold leak (common?). Fuel sending unit goofy too.
Advice Please?
Do you think the miss is due to intake leak?
Do you think the miss causes the computer to keep the tranny out of OD? How much work to do the intake man. What's involved in replacing solenoid in tranny? Remove pan/valve body? Or more involved?
Thanks for looking.
Google
Web AF
