Applying Alclad2 with a brush?
AllAlone.Gz
09-07-2007, 05:28 AM
So I don't own aan airbrush (yet) but was wondering if it can be applied on small parts with a brush. Just wanted to know if it's possible, and if the results are close to as it if done with an airbrush.
klutz_100
09-07-2007, 05:39 AM
I've done it on VERY tiny pieces but TBH the result was nothing close to the airbrushed effect.
I would recommend that use other metalisers until you get an airbrush :2cents: :)
AllAlone.Gz
09-07-2007, 05:44 AM
Ha. Thanx. See I've got this Alclad aluminum and dark aluminum that im dying to use, but my airbrush doesn't arrive till monday. It just sits on my desk calling my name . . . .
sjelic
09-07-2007, 06:02 AM
Wait for the AB you will not regret it :wink: I found Gunze metal coat best metal paint to use with brush.
cyberkid
09-07-2007, 08:10 AM
I apply Alclad only with AB for areas larger than 1.5mm square. On occasion I use a toothpic for buttons and such but thats it.
Alclad was specifically desgined to be used with AB's, so I stick with the manufacturs instructions unless it teeny tiny detailing.
Stupid_boy
09-07-2007, 08:24 AM
alclad becomes completely dry on brush before you can apply it on your detail. it is my experience.
be carefull, most of thinners will destroy airbrush's o-rings. especially MEK.
always use breathing mask and work on well ventilated area. also, litle dust will easy kill your work.
MPWR
09-07-2007, 09:08 AM
To further Cyberkid's point, this is the kind of thing I brush alclad onto-
http://i211.photobucket.com/albums/bb112/andrejmiller/360-086.jpg
I hand brushed the wheel bolts here with Alclad, over gloss black MM Acryl. OK, the pic is a bit crappy, but in person they have a nice chrome finish contrast versus the matte metal finish of the wheels (airbrushed with MM Metalizer steel).
http://img230.imageshack.us/img230/9226/3600474qb.jpg
The shift knob here is just a straight pin with a black plastic ball head. I dipped the head in Alclad (several times). It worked surprisingly well (and it was easy! :p). Yeah, you can just about see my reflection in it.
But anything much larger than these parts and I would defiantely airbrush.
quadzero
09-07-2007, 02:56 PM
That's an excellent tip, I use those kinds of pins all the time and I'm going to have to try this out. Thanks.
Les
Les
cyberkid
09-09-2007, 01:49 AM
Lol for that method for me to work... I'll probably end up with 4 or 5 pins stuck in the bottle before successfully 'dipping' one..
good tip though.. will try it someday... Hrmm... maybe CAing it to a rod would help me not lose it :rofl:
Steve
Steve
