change oil light keeps coming on
Google
Web AF
sniperkitten
09-06-2007, 03:53 PM
I just changed my oil put 10w30 penz hm in my car like always used tg3397 instead of the nomral ph3397 i normally use. and the change oil light comes on when i start the cars and shuts off about two minutes after every start. Im not sure if I should be worried or not. I have never had this problem before with her and it even baffles the people i alwasy go to for car advise. please put my mind at ease telling me it is nothing to worry about.
thanks so much
sniper
pdigital360
09-06-2007, 04:41 PM
Did you reset the system?
I know I have to do that with my 98.
Turn the key to run but do not start, then press the gas pedal to the floor 5 times in 3 seconds...or is it 3 times in 5 seconds. I can't remember but that's how you do it. The chg. oil soon light will flash a couple times then you are good to go.
sniperkitten
09-06-2007, 04:56 PM
Thank you so much, I tried the 5 times in 3 seconds a couple times thinking that I was doing it wrong or got the timing wrong. Then I tried the 3 times in 5 seconds and the light went of shortly after start up.
dwalmop
09-07-2007, 01:29 PM
'hitting my forehead'
Fram filters are bad!
Google
Web AF
