95 civic overheating...frustrating!!enigma's95 09-05-2007, 03:31 AM my stock 95 civic ex overheats anytime i go driving on the freeway for 30 minutes or more. it doesnt overheat if i drive around town for an hour, but will over heat if im doing 70mph for half an hour, then come to a stop. i drove from visalia to madera (about 1 hour) and it didnt overheat on the freeway, but started overheating when i got off the freeway at a stoplight. same thing when i drove to LA and Fresno. on the way home from madera it overheated while i was on the freeway doing 75. ive replaced thermostat, radiator cap, the fluid, i think thats it so far. PLEASE help! im going out of town again i need to know what to replace before i warp the head gasket (if i havnt already). thank you!! Greenblurr93 09-05-2007, 09:34 AM are you losing coolant? check for leaks. also, do a radiator flush.. if it doesnt help, the rad might be really clogged and need to be replaced. ole'dano 09-05-2007, 12:35 PM You might try testing your coolant temp. sensor to see if it is working properly. Then ensure that you rad. fan is working. I had overheating problems and it turned out that the wiring going to my fan was bad. So sometimes my fan would work and sometimes not. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
