89 Grand Prix Auto Trans adjustment
Google
Web AF
89_GPrix
08-27-2007, 10:23 PM
Is there any way to adjust the bands on a 1989 Grand prix transmission ? 3.1 mpi.
Any specs page on adjustment,s , links etc....
Thnx
troy1
08-27-2007, 10:44 PM
no adjustments can be made.
89_GPrix
08-29-2007, 05:34 PM
No kidding , I was hoping to adjust the bands.
The transmission is starting to slip between 1st and 2nd , any possible cause's issues ,with this years transmission .
Would a new modulator valve help etc....
THNX
troy1
08-29-2007, 08:38 PM
A new mod can help a sloppy 1-2. Its worth a shot anyway unless ofcouse its realy slipping bad.
This:
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SAG&MfrPartNumber=MD28&PartType=1159&PTSet=A
is an excellent mod and is adjustable but you need a pressure gauge to adjust it.
89_GPrix
10-01-2007, 10:22 PM
Update to this post.
Initially said it was the 1st to 2nd gear slip .
Turned out to be 2nd to 3rd , changed fluid and filter , helped a while . Used some lucas trans additive .
Trans is slipping 2nd to 3rd , when you shift manually 1st to 2nd is fine , 2nd to 3rd has a sligh slip if you stay on the gas . Does not slip as bad as in Auto mode.
Can anyrhing be done , would the modulator help or is this trans on its way out ?
Thanks
89_GPrix
10-08-2007, 01:34 PM
Anybody , have any comments ?? solinoids ??
Google
Web AF
