low rpm studderingDUI 08-27-2007, 03:02 PM my car has this weird low rpm studder problem thats been happening for awhile but is just now getting worse...i'll explain, the engine/chassis studder only accures between idle and about 2,500 rpms. during the studdering it looses power but once above 2,000-2,500 there is a sudden rush of power. above that it runs like a champ and is one of the fastest sohc in town. it also has a very erratic idle but only sometimes, usealy on really hot days. any suggestions? thanks guys CivicSpoon 08-27-2007, 04:05 PM when was the last time you changed or checked your spark plugs? DUI 08-27-2007, 05:13 PM when was the last time you changed or checked your spark plugs? about two months ago, lol i changed them thinking that was the issue CivicSpoon 08-27-2007, 06:18 PM On hot days and/or when you're driving it at higher rpms, do you ever smell sulfer (rotten eggs)? Your cat could be clogged. DUI 08-27-2007, 06:56 PM On hot days and/or when you're driving it at higher rpms, do you ever smell sulfer (rotten eggs)? Your cat could be clogged. nope, runs like reggie bush and smells like a victoria secrets model. i have smelt my cat go off but not often and when i do it's not when i'm racing around. Greenblurr93 08-28-2007, 08:52 PM above that it runs like a champ and is one of the fastest sohc in town that isnt saying much..:grinyes: just kidding, i had to.... Anyway, how about you fuel filter? o2 sensor? DUI 08-29-2007, 12:48 AM that isnt saying much..:grinyes: just kidding, i had to.... Anyway, how about you fuel filter? o2 sensor? i also changed out the fuel filter when this started happening a few months ago, i havn't checked the sensor but would that really cause something like this, it's very predictable lol it happens everytime. i can't take off from a stop with out it going du du du du du until it hits 2,000rpms unless i rev high and burn the clutch Greenblurr93 08-29-2007, 10:50 AM hmm.. maybe, at idle it may be getting a wrong reading and causing your A/F mixture to be off. any is possible with cars... DUI 08-29-2007, 11:26 PM hmm.. maybe, at idle it may be getting a wrong reading and causing your A/F mixture to be off. any is possible with cars... which sensor would be bad? intake or exhaust? Greenblurr93 08-30-2007, 06:46 AM hmm... could be either... get a FSM and check both DUI 08-31-2007, 02:29 PM hmm... could be either... get a FSM and check both FSM? Greenblurr93 08-31-2007, 03:30 PM Factory Service Manual DUI 08-31-2007, 08:51 PM Factory Service Manual how do i test it? Greenblurr93 09-01-2007, 12:10 AM go buy a FSM and it will give you step by step instructions vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
