Calling all tranny experts. 4l60e
Google
Web AF
prankstar
08-23-2007, 02:57 PM
I recently removed my engine and tranny for an engine rebuild that I'm in the process of doing. I put my tranny on the engine stand now by itself and started inspecting it. I'm a little worried about some things. I noticed that the output shaft has a decent amount of play. How much is normal? Would there be alot less if the torque converter was bolted to the flywheel? Also the torque converter worried me. I drained it and when I was flipping it over to put it back on I could hear and feel something inside of the torque converter moving (like flopping around not a spinning motion). I know that there is different components inside like a stator but I'm not sure if it should be able to move around like this.
1994 c1500, 2wd, 5.7l
777stickman
08-23-2007, 08:07 PM
As far as the output shaft movement. The thing that stabilizes the output shaft is the driveshaft yoke. There is a seal (for oil control) and a bushing in the tail shaft that the yoke slides into. The noises in the t/c I don't have a clue. If it was running good before you yanked it, it's probably ok.
Maybe someone with more experience will step in...........Steve
maxwedge
08-23-2007, 10:45 PM
Correct on the out putshaft issue, the convertor stator and driven member will move around the TC ( normal), they can be cut open and repaired very cheaply, maybe 150.00
Google
Web AF
