91 Camry a/c compressor wont shut offscotts492000 08-23-2007, 09:59 AM My 91 camry with 4 cylinder engine has a/c problems . The a/c blows nice and cold no problems , Fans are running just like they are supposed to , the problem is if I hit the button on the dash with the green light on it to turn off the a/c compressor it does not turn it off . The light does go off but the compressor still runs and cycles as if the button was on . If I turn off the blower switch the compressor does shut off as it should . I would think the push button switch is working due to the fact the light goes off , but what else could it be ? I will test the switch this weekend to be sure it is working . Anyone have any other ideas ? Brian R. 08-23-2007, 01:35 PM Compressor clutch relay stuck? davemac2 08-23-2007, 01:56 PM It won't be the clutch relay if he can turn it off with the blower motor. The blower fan switch in the off position will cut power to the A/C amplifier module and turn off the A/C. If you look at the A/C schematic in the A/C manual section p4: http://www.camrymanuals.com/index.php?m=Home&cid=105&topicid=0, it looks like there are 3 wires which come off the A/C switch. One is from the blower/heater relay, one goes back to the A/C amplifier, and the other provides switched power to the indicator light whose other end goes back to the A/C amplifier as well. Depending upon the design of the A/C switch, if it is a dual pole design, then it could still work for the A/C light indicator but stick for the pwr switching into the the A/C amplifier module. To test that theory, you can yank out the connector at the back of that A/C switch. If it turns off the compressor, then the switch has to be bad. If it doesn't, then the A/C amplifier must be bad. dave mc Brian R. 08-23-2007, 06:22 PM Right - I misread his description vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
