95 Chevy PU (High Idle)
Google
Web AF
userpete1037
08-22-2007, 02:56 PM
Here's the symptom, I own a 95 chevy P/U(350, 5.7L) and it idles high periodically. The funny thing is that it only does it when the A/C is running. Example, when its sitting still for a while w/AC running it idles high when taking off or accelerating into motion. It idles so high that i have to back off the accelerator to let it shift out of gear then accelerate again. I noticed this last summer only thing is that the first time i noticed it, i saw a sign of power steering fluid coming up out of the cap. I don't know if this means that i have a bad power steering pump or not. I bought this truck a little over two years ago and the transmission had been rebuilt so i doubt that i have a trans problem.
2000CAYukon
08-22-2007, 04:48 PM
Is the high idle only when the A/C is on? Usually a high idle is a vacuum leak.
If this only happenes with the A/C on, then it could be a bad IAC which controlls idle speed bases on commands from the ECM.
//2000CAYukon
userpete1037
08-22-2007, 10:10 PM
Yes, it does it mostly when the A/C is running and every blue moon when it isn't running. Sometimes when i'm at a light or something, if i put it in neutral and rev the engine a couple of times, it stops for a while and starts back. Where is the IAC located?
2000CAYukon
08-23-2007, 03:14 PM
Passenger side of the TBI. Probably around an inch in diameter and screws into the TBI.
//2000CAYukon
userpete1037
08-23-2007, 05:12 PM
Okay, I'll try that. I'm kind of busy these days so it may be a while before i respond i.e. moving into a new home.
Google
Web AF
