amplifier groundBrEnDaNb 08-22-2007, 12:57 AM anyone have a good location for an amp ground in the rear of a 2002 blazer? goser 08-22-2007, 04:05 PM Any bare metal should be fine--scrape away paint. Maybe inside the tire jack holder? I have mine behind the seat so ran mine to under the rear door jamb. Just check your resistance between your ground point and battery neg., should be 1-2 ohms. If it's like 60 you might need to run new ground straps or a dedicated ground. Depending on your wattage you might want to do the 'big 3' anyway. (which i think in this truck might be a big 4). vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
