Jetta 2000 1.8T no forward or reverse when hotspecialist 08-20-2007, 09:56 PM Hi everyone, I need help with a vw jetta 2000 1.8 t.When the cars is cold and start driving,no problem,when the car is hot it won't go forward nor backward untill it cools again and it starts drive normally.No trouble codes found in transmission module.Found 3 fault codes in engine module,17521,16804,16795. Does anyone has or has hear of this problem before? thanks, 2001jettavr6 08-21-2007, 01:56 AM is it overheating? because an engine will shut off most of its abilities to run and drive it the computer thinks it will harm itself. try flushing the radiator to see if you had any clogs or if its really dirty. refill it and run it and see if it gives you the same problem at idle temp. veedubmechanic 08-26-2007, 11:17 PM Sounds like the transmission fluid is very low. specialist 08-27-2007, 01:26 PM Sounds like the transmission fluid is very low. not only fluid level is ok but the transmission has been fully overhauled and it remains the same.I was thinking of the transmission fluid temperature sensor. thanks, specialist 08-27-2007, 01:30 PM is it overheating? because an engine will shut off most of its abilities to run and drive it the computer thinks it will harm itself. try flushing the radiator to see if you had any clogs or if its really dirty. refill it and run it and see if it gives you the same problem at idle temp. Hi, no the car does not overheat and is either overheating.All radiator hoses has been changed and thermostat.Systeem has been completly flushed and fill with engine coolant. thanks, veedubmechanic 08-30-2007, 11:06 PM 17521 P1113 Bank1-Sensor1 Internal Resistance too High Repalce your front o2 sensor. 16804 P0420 Catalyst System,Bank1 Efficiency Below Threshold May need a new cat, but replace the front o2 sensor first. 16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected This could be caused by alot of things, most common is the secondary air pump and rear o2 sensor. specialist 09-12-2007, 10:48 AM 17521 P1113 Bank1-Sensor1 Internal Resistance too High Repalce your front o2 sensor. 16804 P0420 Catalyst System,Bank1 Efficiency Below Threshold May need a new cat, but replace the front o2 sensor first. 16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected This could be caused by alot of things, most common is the secondary air pump and rear o2 sensor. Hi, Thanks for the codes advice.Today i could experince what the do.It is not what the told that the car won,t move forward or reverse.The car will move forward and reverse but does not shift second,third,forth and the ASR lamp start flashing. No transmission code. thanks, vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
