97 with turning issues any advise?Andy943100 08-20-2007, 03:41 PM Hey fellows, Just getting into a 97 grand cherokee 5.2 AWD as a family car. This thing is real ruff to park (any sharper turn). I origionally thought it was just because of the AWD as I have driven an older manual 4x4 truck in the past, but I dont think someone in their right mind would pull something like this out of the dealer. I think what it is doing is called crow hopping. The front tires are skipping jumping squeeling (wearing the crap out of them) any time I take a sharp turn. Forward or reverse. I really have to give it extra gass to keep it moving. Already had the bearings and differential taken care of in the front. I read other threads that said something like this could be caused by a faulty transfer case. I dont know much about transfer cases???? Almost feels to me like if it were a two wheel dirve car the rear differential is locked (like a dragster) and not letting it turn. The jeep only has 83000 miles on it. This seemingly good deal is turning into something else. Any advise is helpful Thank you Andy rattler02 08-20-2007, 06:55 PM Andy check your PM kahjdh 08-20-2007, 09:33 PM Check the CV boots and see if they are ripped. hardisk_c 08-20-2007, 11:47 PM I think the '97's still had the 249 transfer case. . . if so, it could be symptoms of the viscous coupler failure. Andy943100 08-21-2007, 12:13 PM So the consensus is that it is a faulty viscous coupler. This looks like around a $500 job done my self. Will swaping out the viscous coupler completely solve the turning issues? Thinking back the mechanic that did the front end work said that there is a slight noise comming from the transfer case. He said that he thought there was no problem with it though. Is there any possiblity that there is another cultprit? Besides the wear on the tires, how bad is it to run my jeep in this condition? Thanks again Andy breeaad 08-21-2007, 09:49 PM You can also just take out the front drive shaft, which will cure your turning issues. I did this for about a year, before I rebuilt the t-case. bullscricker 08-22-2007, 09:10 PM I had the same problems with my 95 Laredo AWD. I had no idea what was causing it until I snapped a sway bar link and after replacing both, which is recomended when one goes bad, the jumping and jerking has stopped completely. Hope this helps. BTW, I think they are only about 15-20 dollars each. Andy943100 08-24-2007, 12:40 PM Alright, Im ebayin a repair manual. (for reference:) Also it looks like for another few hundred dollars I can swap the entire transfer case for a rebuilt one. This seems to be a better option??? because I need this thing reliable for the next 5 or so years. Is this swap really as simple as it seems, or am I fooling myself? Also it will probably be next weekend before I get a chance to mess with it at all. ***I will pull the front drive shaft and take it for a ride. If it seems to steer "normal", will this be the way I should expect it to dive with a proprely functioning transfer case???*** Thanks for the help so far. Any more advise before I get my hands dirty is great. Thanks Andy Cam7 08-29-2007, 05:42 AM Replacing the same kind of transfer case is fairly simple, it shouldnt be a problem for you. Steburd 08-30-2007, 10:59 AM I have the same problem on my 97. I brought it to the mechanic and they said that everything checked out, and they can't find the reason for the hard park. rattler02 08-31-2007, 12:10 PM Replacing the same kind of transfer case is fairly simple, it shouldnt be a problem for you. Just remember they are heavy :lol: docbugs 09-04-2007, 07:20 PM I had/have the same problem with my 97. When I took it in I was told "Thats just the way the are". Steburd 09-17-2007, 03:48 PM Hi all, I actually printed out this thread, and brought it to my mechanic, and made him check everything liste in the thread. According to him, they were all ok. Also, while he drive it, there was no indication of any hard turns. After a full check up he decided to just park it and tell me that, it was just the way the car is. But, as he parked the car, he couldn't turn the wheel!!! So he figured out that it was the power steering pump. He changed it, and the car turns much better!! Good luck! Andy943100 09-18-2007, 10:42 AM I have had power steering pumps go out in the past. This is way different from my previous experience. My car has mostly been sitting, but i had to drive it down the expressway yesterday and that transfercase is making a nasty hum. Should have a full rebuilt t-case comming around thanksgiving(next long weekend I get a chance for anything). I will dig this thread up and post the results (hopefully improvements) once it finally gets done. abregar 09-22-2007, 12:02 AM If it won't idle through a turn then the vc in the t-case is headed south. From the research that I have done they are only good for about 70000 miles. I currently have this problem with my 95 Laredo. Andy943100 11-20-2007, 12:39 PM hey again, I got that transfercase changed. The car turns great. With the case I also put 4 new tires on the car, which I learned is very important with these full time all wheel drive vehicles. All the tires need to be identicle(make, model, and wear), and rotated every 6000 miles. The old case came out easily and the new one went in even easier. I used a company based out of Oakland called transfercase espress. (www.transfercases.com (http://www.transfercases.com)) They were great. They have everything at amazing prices. The only problem I seem to still be having is when I try to put the transfercase in neutral or 4Low it grids when the transmission is put in gear. If I really throw and force the transfercase lever I sometimes can get it without grinding. I am sure this is only a problem with the linkage not fully enguaging the transfercase, but I really dont know how to make the adjustments. I will gladely accept any advise in this issue. Thanks for all the help. The car turns great. NO skipping, hopping, or squeeling AT ALL. Also there is no noise comming from under the car. reekor 11-21-2007, 01:08 AM Try shifting it while moving, 2-3mph. I just had the same problem with a 96 with only 80,000miles on it. I ended up kicking the quadra-trac case to the curb and went with a selec-trac, better case with 2wd and part-time 4d added. hey again, I got that transfercase changed. The car turns great. With the case I also put 4 new tires on the car, which I learned is very important with these full time all wheel drive vehicles. All the tires need to be identicle(make, model, and wear), and rotated every 6000 miles. The old case came out easily and the new one went in even easier. I used a company based out of Oakland called transfercase espress. (www.transfercases.com (http://www.transfercases.com)) They were great. They have everything at amazing prices. The only problem I seem to still be having is when I try to put the transfercase in neutral or 4Low it grids when the transmission is put in gear. If I really throw and force the transfercase lever I sometimes can get it without grinding. I am sure this is only a problem with the linkage not fully enguaging the transfercase, but I really dont know how to make the adjustments. I will gladely accept any advise in this issue. Thanks for all the help. The car turns great. NO skipping, hopping, or squeeling AT ALL. Also there is no noise comming from under the car. Automotive Network, Inc., Copyright ©2012
