tach hook upgeojoh 08-19-2007, 05:06 PM I have an autometer tach that I want to hook up to RAMJET motor with a stock late model ignition system. Where can I tap into the ignition system to pick up the pulse that that will drive the tach to the engine RPM? Thanks, geo taillight 08-19-2007, 05:52 PM Please tell what the year, engine size, make and model of engine. geojoh 08-19-2007, 07:43 PM The engine was purchased in a crate from a chevy dealer. It is a chevy 350 ci Ramjet. It is installed in a 1970 Chevy II I think RamJet first came on the scene in about 1996. Thanks, geo taillight 08-20-2007, 08:42 AM If it is a 1970 distributor look on the top of the distributor cap. One terminal is marked Batt the other is marked Tach. silicon212 08-20-2007, 11:49 AM If it is a 1970 distributor look on the top of the distributor cap. One terminal is marked Batt the other is marked Tach. Not on a 1970 distributor. Only on HEI, which came into being '74-'75. geojoh 08-20-2007, 12:10 PM The iginition system is the one that came on the RAMJET motor when it was purchased about 3 years ago. It is not an HEI system it is a generation or two newer that HEI. Thanks, geo 777stickman 08-20-2007, 09:07 PM 1. RED wire to 12v ignition source 2. GREEN wire to NEG side of coil. 3. BLACK wire to good GROUND. 4. WHITE wire to instrument panel lights source. geojoh 08-22-2007, 06:23 PM The last post looks like the wires coming off the tach not the wire, from the ignition system, I need to hook to the green wire from the tach. The coil for the ignition systen that came on the RAMJET engine has two connectors on it. A grey one with pink and a white wire. A black one with a green and a red wire. I believe the grey one comes from the distributor. So now where do I hook up the green trigger wire that comes off the tach? 777stickman 08-22-2007, 07:13 PM The last post looks like the wires coming off the tach not the wire, from the ignition system, I need to hook to the green wire from the tach. The coil for the ignition systen that came on the RAMJET engine has two connectors on it. A grey one with pink and a white wire. A black one with a green and a red wire. I believe the grey one comes from the distributor. So now where do I hook up the green trigger wire that comes off the tach? This is speculation only. I don't have a clue as to what you have for an ignition sytem. So, disconnect both connectors and probe all 4 contacts for 12v ignition voltage, probably the red one. Do not hook the GREEN tach wire to this one. You have 3 left. Good luck...........Steve Please post back which color wire worked so that others can see the results. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
