96 Camry rear windows don't work
RMHayes1954
08-19-2007, 04:38 PM
96 Camry 4 door - front windows work OK but left rear went half way down, got stuck, now neither rear window works. User manual shows fuse (or circuit breaker)#34 in Instrument Panel fuse panel (is there one breaker just for the rear windows?). Opening Instrument Panel, there are fuses, but instead of the circuit breaker there is an OBDII port in there. Opened right and left kick panels and looked in the two driver side under-hood fuse boxes and under the dash, but I cannot find a fuse or circuit breaker for these rear windows.
I already went through your Camry threads - plenty on windows, checked the suggested locations, but I can't find this circuit breaker. Any suggestions will be appreciated.
RIP
08-20-2007, 04:28 AM
According to the schematic for your windows:http://www.turboninjas.com/camry/camry94wiring.pdf (starting pg 156) if the fuse blows, all your windows would be dead. Suggest you take off one or both rear trim panels and check for power at the motor connector with the switch thrown. If its there, time for a new motor. If it's not, could be the switch.
The schematic is from the Factory Service Manuals thread at the top of the forum. Open up the body electrical pdf file for even more info.
