4WD switch question
Google
Web AF
theforce2723
08-13-2007, 11:48 PM
Hello,
I have a 2002 Trailblazer LTZ. The lights on my 4wd selector switch are out. About a year ago I had a problem where all 4 lights would flash or stay on and it would not go into 4WD, and after searching on the internet, tried to pull the fuse for the ETC (#23 I think) and this solved the problem. Every now and then if you start the vehicle and shift too fast into drive the lights will flash until you turn the vehicle off, re-start it, and shift it slower into drive. This weekend my lights on the switch all went completely out, with the vehicle stuck in 2WD. I tried pulling the fuse...to no avail. My question is does this sound like a bad switch? I'm trying to troubleshoot this on my own as opposed to taking it the dealer and paying $$$ for something I could fix on my own. It is the original switch (4WD hasn't been used since February 2007) and my TB has about 70K miles on it. Thanks for the help.
Brad
taillight
08-14-2007, 09:23 AM
Will it go into 4 wheel drive?
theforce2723
08-14-2007, 10:05 AM
No, it will not go into 4WD, just stuck in 2WD. I tried putting it in 4hi and 4 lo...nothing happens...Thanks, Brad
taillight
08-14-2007, 10:52 AM
First use a scan tool and look for any trouble codes. Brakes will not allow transfer case to shift. Check fuses. I think there are 3 fuses #5 for illumination, #15 for power and # 23. Then check the switch for power and ground. Another book says #s 2 trans. case ,4 guages,14 illim.,24 4 wheel drive. Check your owners manual for fuse numbers.
theforce2723
08-15-2007, 10:34 AM
Thanks for the info taillight...I am not thinking to clearly. I forgot to check the fuses first. I replaced the switch this morning...that wasn't the problem. If the fuses are ok, what do you think I should try next? The dealer??? $$$
Thanks,
Brad
Cat Fuzz
12-11-2008, 11:57 PM
I know this is an old thread but I wanted to post the solution to the problem so others may benefit:
I had the same Trailblazer with the exact same problem. No lights on the switch and nothing but 2WD. I fixed it by replacing the transfer case controller. It's located up under the dash. I bought a used one from a wrecking yard for $67.
royals1969
12-19-2008, 06:16 PM
Catfuz: i just picked one up for $90 bucks used , i have a 2002 TB, before i rip my trailblazer apart, which side of the dash is this located, drivers side or passangers side? just want to know which side is best to attack it from..Thanks..Royals
MT-2500
12-20-2008, 10:15 AM
This Post is old and gone Dead.
Let the dead rest in peace.
Throwing parts at it without proper testing can get you in a world of hurt :rofl: :lol: :lol2: :grinyes:
If you have a problem on yours start a New Thread/post and give all info on yours truck and someone will help you.
Google
Web AF
