Another new addition to my growing WIPsxpeed 08-12-2007, 06:45 PM I had to pick these up today when I saw them. I've always wanted to build a Chaser and now I get to. :grinyes: All for $34. I think I'll go back to get a Bomex RX-7 and a Nissan Cima VIP. http://i3.photobucket.com/albums/y78/xpeed/DSC00200.jpg xpeed 08-11-2008, 01:21 AM I ran into some problems with the paint. Will aircraft stripper damage the plastic mold to take the paint off? http://i3.photobucket.com/albums/y78/xpeed/DSC00206.jpg http://i3.photobucket.com/albums/y78/xpeed/DSC00207.jpg rockinanko 08-11-2008, 02:04 AM Hi, i think you got the same problem as i had many years ago... this paint job is straight from the spray can right? did you prime the car body first? you do one attempt of super thick /wet coat right? your spraying distance is not constant right? you know the spray can leftover is not enough to cover the whole body but you risk it, right? if the aboved mentioned is true, then i can help you... cheers! xpeed 08-11-2008, 02:36 AM Hi, i think you got the same problem as i had many years ago... this paint job is straight from the spray can right? did you prime the car body first? you do one attempt of super thick /wet coat right? your spraying distance is not constant right? you know the spray can leftover is not enough to cover the whole body but you risk it, right? if the aboved mentioned is true, then i can help you... cheers! I painted this model a year ago as you can see from when the thread was made. Yes, it was straight from the can Yes, I didn't primer it like an idiot I didn't coat it thick My spray distance was probably not consistent Yes, I do know a left over spray can isn't enough, but in this case, I was using a new one. I usually use the leftover cans for small parts and bits in the future. -Thanks mate -cheers drunken monkey 08-11-2008, 10:55 AM did you wash and/or sand the body? MPWR 08-11-2008, 11:07 AM Will aircraft stripper damage the plastic mold to take the paint off? Yes. Try isopropyl alcohol. rockinanko 08-11-2008, 12:56 PM Yes, it was straight from the can Yes, I didn't primer it like an idiot I didn't coat it thick My spray distance was probably not consistent Yes, I do know a left over spray can isn't enough, but in this case, I was using a new one. I usually use the leftover cans for small parts and bits in the future. http://i190.photobucket.com/albums/z217/sbc3133r/ww1.jpg take a closer look at one of my builts, some 10 years ago... i suffered the same fate as you too, never prime cos' i thought i can cover the grey body base with such a dark color + thicker coats...etc. what i can conclude is; 1) washing the body with lukewarm soap is good prior to painting...there seem to be some lubricant from the maker's molding machine which we can't feel it but the paint picks it up & then 'protest'. 2) lightly sand the whole body with 2000 grit sandpaper to make some 'tooth' for the paint foundation. 3) primer...til recently i then finally / fully understand the very importance of it, to provide more tooth & consistency to the color paint & to check for body errors. 4) for your case, since it's a tamiya, fujimi or aoshima (better polymers) + not primed...you can use used brake fluid to strip the paint easily. you'll have a harder time if it's primed cos' maybe the primer pigments are more resistant to brake fluids. the reason why we had this white lines in between the fitting parts is because spray cans churn out much larger pigment microns compared to airbrushing. this bigger microns can't 100% fill into those tiny fitting lines, that's why we still can see the original color base even after sprayed. please, don't say "no prime = idiot"...we're all here to 'check' our shortfalls & share our 'shortcuts' in the quest to build that one model we desire... but if you insist on saying it...then that makes the 2 of us!!! hehe...:evillol: xpeed 08-11-2008, 01:55 PM ^ Thanks so much. Since it was sitting in the box for a year, the paint fully set, so it'll be lot harder for me to take it off. Thanks for all of your guy's help. Much appreciated. rsxse240 08-12-2008, 12:56 AM 90% or higher isopropyl alcohol should still strip that paint pretty quickly. Just set it in a tupperware container and fill it with alcohol, fully covering the body, and let it set overnight, scrub it with a SOFT toothbrush, and if it doesn't strip all of the paint, or if the paint is just softened and doesn't come right off, let it set in the alcohol for a week, a month, a year.... It will strip it off, but it may take some time. xpeed 08-12-2008, 03:40 AM ^ Thanks, I'll do that. *Hits the local drug store* vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
