2005 CRV Accessory Plugs not working
backman2007
08-06-2007, 05:28 PM
I have a 2005 CRV and both the front and rear accessory plugs do not work. I checked both fuses and they are fine. I have tried different items in the plugs and nothing. Thanks in advance for your help.
Larry
MT-2500
08-06-2007, 07:59 PM
Larry
Welcome to AF
Are you getting power to the plug in?
backman2007
08-06-2007, 09:17 PM
Thanks for the reply, but I do not know how to check for power to the plug. I did try and plug in my portable air compressor and it did not work. It works well with the accessory plug that was added for the breaking system for the car when it is being towed behind the motorhome.
MT-2500
08-07-2007, 10:04 AM
A good old 12 volt test light with a 12 volt bulb is a good tool to check for 12 volt power and can be reversed to check for good ground.
Also a good tool for fuse checking.
Most parts places have them in there tool department.
MT
backman2007
08-07-2007, 07:36 PM
Thanks,
I will let you know what I find!
backman2007
08-08-2007, 09:51 PM
I checked and there is no power to either plug. I may have to take it back to the dealer for repair. Thanks for you help.
Larry
MT-2500
08-09-2007, 10:00 AM
Larry
You are welcome.
Go back over all fuses.
Under hood and under dash and test for 12 volts on both sides of them.
Good luck.
MT
