T-Rex cam
Google
Web AF
Mazdarider
08-04-2007, 11:51 AM
What is the opion of anyone out there on the T-Rex cam, Lingerfelt 243 cast number heads, and the Lingerfelt cam? Is a 215cc head to big or should i go with the AFR 205cc?
Mr. Luos
08-05-2007, 12:15 PM
Drag?
Street?
I think the T-Rex is a little big for a street car.
Morley
08-05-2007, 12:52 PM
If this is going to be a daily driven car then the heads are way too big and so is the cam. For street use you want 195cc intake runners and a cam with 112-114 LSA with less than .520 lift, closer to .500 lift or less would be better.
Mr. Luos
08-05-2007, 03:19 PM
Morley...that is basicly stock LS1 heads and cam. Heads aren't that big, but they are somewhat close.
Stock LS1 cam is right at .500 lift.
224/224 581/581 114 is my idea of a perfect streetable cam in an LS1.
AFR 205's would go well with that cam in my opinion.
Still, call Thunder/TSP and talk to them first.
Morley
08-05-2007, 08:41 PM
Well, he didn't specify what engine so I assumed a Gen I SBC. The LS-x engines are a different animal and the same rules don't apply to them. Still 215 intakes would be allowing the incoming air to slow too much unless you are always running in the higher RPM range, and have an exhaust able to get rid of all that air as well.
Mr. Luos
08-05-2007, 09:55 PM
True.
I heard T-Rex and knew it was an LS1 grind. I shouldn't have assumed.
Thunder Racing Custom Camshaft
T-ReX v.2 - 242/248 - .608/.612 - 110 lsa 3500-6700 RPM Power Band. Violent mid-range & high RPM power. Requires computer tuning, 4000+ converter on autos, 4.30's or greater depending on transmission. Works very well with nitrous and proper tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Due to the extreme nature of this camshaft, piston to valve clearance must be verified when using modified cylinder heads.
From Thunder's website.
That is a very large cam for a stock cubed LS1. Piston to valve clearance gets pushed a little too close for me. Not sure of the exact amount of clearance, but it isn't enough for my liking.
Mazdarider
08-05-2007, 10:22 PM
Yes it is a Gen-III SBC 346 LS1 to be exact come on I've never seen the T-Rex on any other GM vehicle. But no its not a daily driver, its a strip car, mostly but one I take to a classic car gathering on occasion. The T-Rex is what i'm going to run but someone at the strip was bragging about the Lingerfelt cam gains of over one hundred hp. I call bullshit but if its true that will go in, but the heads i have not decided on, 205, or 215cc AFR heads, I'm not sure if the 215 are to big or not, I've heard different things from different ppl. So if anyone really knows and isn't just slinging some bs i'd like to know. I don't mean to be rude but some ppl just hear some phrases and get on hear and repeat them to try and sound smart.
Mr. Luos
08-05-2007, 11:04 PM
What are the specs on that Lingenfelter cam? 100 HP is a HUGE stretch. Sounds like an SLP claim. :lol:
And I think it is 205 or 225 on the AFR Mongoose heads. Probably want the 205cc heads if it is stock cubed.
What gears are in the car? M6 or A4?
What are the goals? ET and power wise?
And just an FYI....the LS1 is a GenIII SBC.
And I try not to sling much BS...but it happens.
stieh2000
08-06-2007, 04:37 PM
Yes it is a Gen-1 SBC 346 LS1 to be exact...
Out of curiosity, where did you get that Gen 1 from? The LS1 is a Gen 3 engine.
Morley
08-07-2007, 03:11 AM
If it is a strip only car (running 5-6k RPM for most of the time) and you have a very large exhaust, then the 215 heads may be just what you need..if you have a modified inlet tract..ie intake, throttlebody, breather inlet tube/ CAI. WIthout those higher flowing items, larger heads won't get fed the air they want/need.
And 100 HP gain just on a cam change...not unless it had the wimpiest cam GM made in it to begin with.
Mazdarider
08-07-2007, 12:08 PM
TYPEO SORRY
Mazdarider
08-07-2007, 12:24 PM
The car only gets driven on occasion to a hot rod gathering, it has a 4.10 gear, and a full set of bolt ons the only thing left is the heads, cam, and the new intake manifold-FAST 90mm with the nick williams 90mm throttle body. It has no cats 3in exhaust. Magnaflow cat back, Zex nitrous 125 shot, maybe going to upgrade to a 150.
Mazdarider
08-07-2007, 09:01 PM
Also I was wondering what you think of the Magic Stick 3 and 4
Mr. Luos
08-07-2007, 10:44 PM
Those big cams NEED the 4.10's you have.
That is a lot of cam. They make great power. Sounds like you are fairly set-up for one though.
I would call TSP/Thunder and talk with their tech guys and let them know what you have planned. Might recommend something smaller with more separation between the intake and exhaust duration to assist with the nitrous.
Mazdarider
08-08-2007, 02:47 PM
From what I have read the T-Rex works very well with nitrous. I have spent hours on the computer looking through articles, and looking on different websites. So i guess thats prob. what I will run, with either the AFR 205cc or the Trick Flow 205cc heads, but the FAST 90mm in take and the nick williams throttle body 90mm. I will also replace the rear end with the moser 12 bolt, and my clutch with something I have decide what yet, also torque arms and verious other suspension parts. So it will be upwards of 6-7 grand including the labor cause i sher as hell aint puttin in that damn rear end, or those heads
Mr. Luos
08-08-2007, 03:02 PM
Kinda off topic...but is the car an M6??
poormillionaire2
08-08-2007, 07:31 PM
Not a huge fan of the MS4 cam. Its a dyno cam. You have to get the revs up really high to get that cam in its powerband. I've heard it get beat on the street by smaller 'under the curve' cams. A lot of those cams mentioned are big cams though. I've heard good things about the Torquer 2 cam.
Mazdarider
08-17-2007, 03:20 PM
What about torquer 3? The website says the MS4 has a power band of 2100 to 6700 or something like that.
Mazdarider
08-19-2007, 01:14 PM
The car is an M6 with the B&M ripper shifter
Mr. Luos
08-19-2007, 04:56 PM
It doesn't come on strong until about 4,500. Sometimes later...it all depends on the mods around it.
With the 4.10's though, it wouldn't matter if you can launch from 4500 and up.
Mazdarider
08-20-2007, 11:44 AM
Well that was the thing about the T-Rex I am going to put in a 12 bolt, and slicks so I can launch it. I'm having the connecting rod bolts replaced so I can turn it about 7300.
Google
Web AF
