98 Caravan Clockspring Airbag Lighttrackshoes 08-04-2007, 05:35 AM Airbag light is on, horn doesn't work. Replaced clockspring but that didn't fix problem. Any suggestions? Thanks rpresley 08-04-2007, 04:27 PM That is the only fix I know of for that problem. There is a permanent warranty on 98 and other year models for clock springs. When mine went out I lost the horn, cruise control and air bag light was on. Dealer fixed it for free! RlpinSTL wafrederick 08-05-2007, 12:49 PM I agree,take it to the dealer and they will fix it for free for a lifetime warranty.It starts at 1996 and up minivans. HeadlessHorseman1 08-05-2007, 08:51 PM There have been several SERIOUS recalls on your vehicle. Defective Clock Spring and Fuel Rails are two that come to mind. There may be a problem with the inlet port to the fuel tank that could cause your vehicle to explode during a fill-up. Get your VIN and go here to find out if you have any outstanding recalls on your vehicle. Do it NOW: http://www-5.dodge.com/webselfservice/dodge/index.jsp?screenName=recall&country=us&emailUrl=goToEmailForm%28%27R%27%29 Then take your vehicle to a dealer. The work is free. Chrysler is required by LAW to fix the clock spring problem because it affects the functioning of your driver-side airbag system (and other non-safety-related items as well). Make sure your Fuel Rail recall work is done or your vehicle could burn to the ground with you or family members in the vehicle. Oh, and don't forget to check out the fuel tank inlet port thing... 20 gallons of fuel in your tank makes a big bang when it explodes... the 10,000 gallon tank in the ground near or under your vehicle makes an even bigger bang. :( Do NOT stop until you get this FREE work successfully done. Your life may depend on it... Good Luck! heron15630 08-19-2007, 11:14 AM Hi would anyone know whether this warranty covers European countries as I seem to have the same problem with my 99 Grand Caravan coopdavillage 08-19-2007, 10:04 PM a tip, from what i found out the clock spring may not fix the problem and the dealer told me that when he replaced mine no more than a week ago. my horn cruise control and im not sure about the airbag; dont work but i also do not have an airbag light on. (97 voyager) mwilkinson11 02-10-2008, 11:38 PM This may sound dumb, but did you try checking your fuses? I had the same problem, went round and round with the dealer, finally took it home, decided to check the fuse box, guess what? I had a blown fuse.:banghead: Automotive Network, Inc., Copyright ©2012
