AC 1996 4 cyclinder S-10anne new 08-04-2007, 04:26 AM When changing air cond comp. how much oil is used, what kind, and how should it be put in the system? Thanks:banghead: Anne MT-2500 08-04-2007, 10:36 AM First you need to drian old compressor and see how much is in it. If old compressor has no oil in it system may be low on oil. Also drain new compressor if it came with oil in it. Some new compressors the put the total system charge in them. If so drain it out. I would add about 3 oz of pag oil to new copressor. Put it in compressor. And always spin the compressor by hand before running it. Vacuum system down and charge with 2 lbs of R134a anne new 08-04-2007, 02:21 PM MT, Thank you for answer. Will let you know how it works! You know here in the Sunshine State we need AIR COND. almost 11 or 12 month out of the year! he he MT-2500 08-04-2007, 02:42 PM MT, Thank you for answer. Will let you know how it works! You know here in the Sunshine State we need AIR COND. almost 11 or 12 month out of the year! he he You are welcome. But look at what the sunshine saves in cutting wood for the winter.:grinyes: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
