DTC code p1875
RPerformance
08-02-2007, 12:22 PM
Has anyone had a problem with a P1875 Code??? = 4wd Low Switch Circuit Electrical
Most importantly know the fix.
MT-2500
08-02-2007, 12:59 PM
Year and engine and transmission and transfer case and mleage?
As The code says switch circuit electrical open or shorted problem.
You will need a good scanner and a volt ohm meter to start with and some good repar info on the wiring and switching.
A good repair manual has a repair flow chart for that code.
RPerformance
08-02-2007, 01:07 PM
it is a 2003 not sure on the t-case. just a standard AV with a 5.3 and I assume a 4L60e? I know it was built 1/03. Mileage is around 110k.
It has also had a problem going to 4 hi and 2 hi on its own at least according to the dash switch, replaced switch and no change, this was done 5 months ago and no codes at that time. now it has the 1875. I have a voltmeter, an Actron scanner (limited live data), but no schematics.
MT-2500
08-02-2007, 02:13 PM
Your best bet would be the all data online sub.
Or A factoty repair manual .
http://www.alldata.com/products/diy/index.html
ronbo123
06-11-2008, 11:40 AM
Please Email me directly if you still have this problem. I had it and it is fixed... Cost was $0.00 and took 3 minutes...
Nightmoves@roadsiderage.com. or RSPokrak@aol.com...
MT-2500
06-11-2008, 11:47 AM
Best to keep all answers and post here in the origional post so everyone can see and kelp on the problem.
And be carefull about posting your e mail add in open forums.
A lot of people harvest e mail adds for the money in it.
You may wind up on ever hit mail in the world.:lol2:
MT
