Banging noise when turning leftsouthpaw2_4 08-02-2007, 12:06 PM For some wierd reason every time i turn left and its bumpy the truck lets out some violent banging noises...as if something is smashing against the frame...or popping out. I can't explain what it is and hoped that someone else had this situation before. My mechanic just did my ball joints so they are fine, the tranny mounts have been retorqued along with the torsion bar crossmember. Please help! MT-2500 08-03-2007, 01:29 PM Welcome to AF It may not be safe to drive. Somebody needs to craw under there and have a look at it.:grinyes: I your mechanic just done ball joints I would take it back and have him check things over. Let us know what you find or how it goes. MT Ultrashock 08-04-2007, 10:55 PM Welcome to AF It may not be safe to drive. Somebody needs to craw under there and have a look at it.:grinyes: I your mechanic just done ball joints I would take it back and have him check things over. Let us know what you find or how it goes. MT I've had this problem for years now, first i thought it was a broken bracket on the sway bar, then i thought it was the ball joints..... but it was neither one. No mechanic has found what is wrong with it, and i've spent plenty of time down there and cant figure it out......... old_master 08-05-2007, 09:19 AM What year vehicle? 2 door or 4 door? 2WD or 4WD? Manual transmission or automatic? laxman21 08-06-2007, 08:59 AM I've had this problem for years now, first i thought it was a broken bracket on the sway bar, then i thought it was the ball joints..... but it was neither one. No mechanic has found what is wrong with it, and i've spent plenty of time down there and cant figure it out......... Me too. My mechanic said he tightened a bolt and it went away for a week or two, then came back. southpaw2_4 08-07-2007, 10:33 AM its a 1994 Jimmy 4 door with auto tranny. Yea i can't figure out the banging either...and i am at the point where i just want to say screw it and drive the truck with the noise. But i was up 4x4ing in harrison and its just scarry hearing that banging/popping sound everytime the truck contorts to the grade or a bump. blazes9395 08-07-2007, 12:30 PM Check and make sure your torsion bar mounts are not broken. Is the noise coming from under your front seats, or the front end? Also, check your control arm bolts/studs and make sure they are tight. baybum1 08-07-2007, 01:11 PM I've got the same problem, also when braking hard or coming to a stop. It seems the noise is coming from the left rear to me. liloldbeater 08-08-2007, 02:55 AM Just had the same loud banging under my truck. Changed the torsion bar mounts and the noise was gone. The old mounts were trash, it took me about 2 hours with a little :popcorn: envolved! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
